How about a official app for iOS/TVOS?
Davidpriddy
Post Fri Nov 03, 2017 7:11 pm
You only seem to support Android devices, let's get some love for Apple here!
Post Fri Nov 03, 2017 9:42 pm
Re: How about a official app for iOS/TVOS?
Actually, Serviio doesn't support any particular platform for playback. The Android app you are referring to is offered by a 3rd party, who by the way has done an outstanding job. With Apple, there's a lot more hoops to jump through to get an app into the iTunes store. Probably why no one has made one yet.
That said, Infuse works with Serviio just fine, although you need the paid version to support some necessary audio and video codecs.
Davidpriddy
Post Sat Nov 04, 2017 8:58 am
Yea, VLC app works great too with Serviio.
thymon
Post Tue Nov 07, 2017 2:48 pm
You can't use VLC or FUSE to 3G ou 4G.
I use Serviio for multi user over external IP, so I use Mediabrowser with Safari or Google Chrome :(
Post Tue Nov 07, 2017 3:08 pm
thymon wrote:You can't use VLC or FUSE to 3G ou 4G.
Correct. The only way to use Serviio on an external network is with MediaBrowser. Not sure if there's any 3rd party apps (such as ServiiGo) that might work externally.
Davidpriddy
Post Wed Nov 08, 2017 1:38 am
3G/4G? I'm assuming you are referring to cellular usage? I don't do that lol
Post Wed Nov 08, 2017 12:28 pm
I believe he was just referring to any connection outside your own network. But yes, cellular is one way to access it. Another would be Wi-Fi at some other location. ;)
Return to Feature requests
