Panel upgrade movies
Fabiolik
Post Sat Dec 09, 2017 4:59 pm
Hi everybody,
during the transmission of films, from Mac to various televisions, the Serviio panel updates the entry of new films and their reproduction. Is it possible to see this panel disappearing for longer? The display time is really small, less than a second. Is there a way to make it last longer?
Thanks in advance
Post Sat Dec 09, 2017 6:31 pm
Re: Panel upgrade movies
To my knowledge, there's no user function or setting in any file to have the added media popup last a longer time. It will be up to Zip to determine if there's something internal that can be done.
Fabiolik
Post Sat Dec 09, 2017 9:48 pm
Thank you, I appreciate...
