issues starting server on Raspberry PI 3B on Raspbian Stretc
I'm pretty savvy with Linux but not so much with Java (not my fav language)
I've installed 1.9
i've installed openjdk-8-jdk & openjdk-8-jre and the other drivers i need but still getting an issue with SOAP
below is an excerpt from the log file where i'm getting the issue, any assistance would be greatly appreciated.
I've installed 1.9
- Code:
2017-12-14 21:52:31,046 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: javax.xml.soap.SOAPException
java.lang.NoClassDefFoundError: javax/xml/soap/SOAPException
at org.serviio.upnp.webserver.WebServer$RequestListenerThread.<init>(WebServer.java:122)
at org.serviio.upnp.webserver.WebServer.start(WebServer.java:76)
at org.serviio.MediaServer.startServer(MediaServer.java:207)
at org.serviio.MediaServer.main(MediaServer.java:158)
Caused by: java.lang.ClassNotFoundException: javax.xml.soap.SOAPException
at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:582)
at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:185)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:496)
... 4 more
