Scan stops at encrypted file
operagost
Post Mon Jan 15, 2018 3:33 pm
I reported this problem back in Serviio 1.5 and it still isn't fixed so I'm warning everyone.
The media scan gets stuck in a loop if it encounters an encrypted file.
2018-01-15 10:21:28,164 INFO [LibraryDeltaScanner] Added repository 'C:\Files\Shares\Media\Audio' to delta scanner (NATIVE)
2018-01-15 10:21:28,489 INFO [LibraryDeltaScanner] Added repository 'c:\files\shares\images' to delta scanner (NATIVE)
2018-01-15 10:21:28,492 INFO [LibraryDeltaScanner] Added repository 'C:\Files\Shares\Media\Amazon MP3' to delta scanner (NATIVE)
2018-01-15 10:21:28,493 INFO [LibraryDeltaScanner] Added repository 'C:\Files\Shares\Media\Video' to delta scanner (NATIVE)
2018-01-15 10:21:28,493 INFO [LibraryDeltaScanner] Starting the library delta scan
And that is it. Now, if you're fortunate, you'll have added some new files that come before the encrypted file alphabetically. Then your clue will be the last file it adds-- you can start looking from there. Or, you may see this error about reading metadata from the encrypted file-- seems to be new as of 1.8.
2018-01-15 10:21:27,591 WARN [MetadataExtractionCoordinator] Cannot read metadata of file C:\Files\Shares\Media\Audio\jace_everett\Jace Everett\burn_for_you.mp3 via extractor EMBEDDED. Message: C:\Files\Shares\Media\Audio\jace_everett\Jace Everett\burn_for_you.mp3 (Access is denied)
Why this gets logged as an error, but it doesn't simply move on, is beyond me.
Post Fri Jan 19, 2018 8:53 am
Re: Scan stops at encrypted file
weird, any chance you can share the file with me so that I can reproduce and try to fix it?
Users browsing this forum: Baidu [Spider] and 33 guests
