IPTV support
Post Sat Mar 26, 2011 5:46 pm
Re: IPTV support
Christopher_Povey wrote:
zip wrote:It is my intention, I just need to know what types of streams there are and people are using, so that I can add support for them
I would like:
BBC iPlayer
ITV iPlayer
4OD
Sky Player
Not sure Sky Player is possible as its strict install on one device only.
no sky player wont be possible as you have to have a sky subscription for it.
DLNAhooray
Post Mon Mar 28, 2011 5:27 am
Re: IPTV support
Version 0.5.2 released
... Now I can finally focus on 0.6, which will bring online content streaming ...
Would this include iPlayer? Say yes and make my day!
Post Mon Mar 28, 2011 11:25 am
Re: IPTV support
That is one of the feeds I'm looking at.
Post Mon Mar 28, 2011 11:27 am
Re: IPTV support
possibly but from what i understand iplayer are limiting what apps can use there sytsem so might not be possible..
Christopher_Povey
Post Mon Mar 28, 2011 1:59 pm
Re: IPTV support
I would like:
BBC iPlayer
ITV iPlayer
4OD
Sky Player
If you had a Sky package (I have Sky HD) would it be possible then?
Chris
Running Serviio on Intel Q6700 Windows 7 Ultimate x64 PC feeding a Sony BDP-S570, Pansonic TX-L37G20B, and a XBox 360.
Managed with Serviidroid via HTC One X
Post Mon Mar 28, 2011 2:16 pm
Re: IPTV support
will see, I have no idea about their API or xml feeds etc. But most likely not in the first version.
Christopher_Povey
Post Mon Mar 28, 2011 3:15 pm
Re: IPTV support
I know I can go to Sky website and register my customer details, I can then download "software" to watch Sky channels on a PC that are part of my package. However the software will only run on that PC, and no other computers in the house. Which is why I questioned if it was possible.
If I installed it on my PC which is running Serviio, I wonder if there is a way to link 'em. I doubt it.
I am more interested in getting Beeb iPlayer on the Panasonic TV and 4OD on my Sony Blu-ray player...
On a different subject Panasonic have added BBC iPlayer to Viera Cast, but only on 2011 model TVs! It might roll out to older TV's then again it might not! :(
Chris
Post Mon Mar 28, 2011 3:17 pm
Re: IPTV support
Christopher_Povey wrote:I know I can go to Sky website and register my customer details, I can then download "software" to watch Sky channels on a PC that are part of my package. However the software will only run on that PC, and no other computers in the house. Which is why I questioned if it was possible.
no this is not possible NAGRA3 prevents this kind of thing...
nttranbao
Post Wed Aug 24, 2011 8:06 am
Re: IPTV support
Sorry if my post may not be relevant to the current topic, but I also want to stream IPTV to my Sony Bravia .
Here is the link on how it can be done with pshare. Hope it will give a hint.
http://ps3muxer.org/pshare.html
Regards,
Bao Nguyen
o.neill
Post Wed Apr 11, 2012 8:47 pm
Re: IPTV support
hello, i have problem with iptv streming to DLNA. IPTV from my intrnet provider is mostly part of mpeg4. only 4 programs are in mpeg 2 format - its ok, and function. in VLC are function all TV programs, but in serviio are function only Mpeg2.
if i want share IPTV link with mpeg4 strem, in logfile will appear:
2012-04-11 18:23:43,156 WARN  [FeedUpdaterThread] Failed to retrieve online item information for http://10.249.1.253:9021. It might not play.
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveAVMetadata(FeedUpdaterThread.java:273)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveTechnicalMetadata(FeedUpdaterThread.java:208)
   at org.serviio.library.online.metadata.FeedUpdaterThread.run(FeedUpdaterThread.java:101)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.validateCodecsFound(FFmpegMetadataRetriever.java:344)
   at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:87)
   at org.serviio.library.online.metadata.FeedUpdaterThread.retrieveAVMetadata(FeedUpdaterThread.java:255)
   ... 2 more
can you help me? thanks (sorry for my english)
btw: serviio is great DLNA server, because is onlyone, where works share IPTV to my LG BD660 player (i dont need share video files, because share from SMB is easier and for me most fumction)
Post Wed Apr 11, 2012 10:04 pm
Re: IPTV support
Where did you get the URL? This doesn't seem to be right or live:
ffmpeg -i http://10.249.1.253:9021
o.neill
Post Thu Apr 12, 2012 5:02 am
Re: IPTV support
this ip adress of iptv server was on server in LAN site of my internet provider. it work only in lan site only this provider in our city. I have plalist from our provider with adress TV programs.
in VLC it work super, but serviio can not work with it when the stream is in mpeg4 (i watch in VLC on details of codecs, and 4 of this programs are stream in mpeg2 and this work in serviio, more 12 TV programs are stream in mpeg4 and not work in serviio, but in VLC it work all.)
thanks
Post Thu Apr 12, 2012 8:14 am
Re: IPTV support
post output of the ffmpeg command above. what is your device?
o.neill
Post Sun Apr 15, 2012 6:01 am
Re: IPTV support
Hello, I have anyone informations of my problem, with any pictures(printscreens)
on left side of pictures is Serviio, on right is VLC
this is example of function program IPTV -> DLNA (in VLC is playlist of IPTV prom my internet provider):
programs with this codec from IPTV are no function (in VLC is playlist of IPTV prom my internet provider):
and this is sumary (in VLC is DLNA server of SERVIIO and data in window "Informace o médiu" are from prime playlist from provider):
i have LG Blury Player BD660 and DLNA server SERVIIO works as well as in VLC
thanks
Post Sun Apr 15, 2012 9:27 pm
Re: IPTV support
post ffmpeg -i http://xxxxxxx for the stream
o.neill
Post Sun Apr 15, 2012 9:42 pm
Re: IPTV support
Write me please, how do I post?
Post Mon Apr 16, 2012 9:17 am
Re: IPTV support
execute ffmpeg (in Serviio's lib folder) and pass it the URL of one of your streams, like:
Then post the output here
o.neill
Post Sat Apr 21, 2012 1:17 pm
Re: IPTV support
if I start ffmpeg, so the window appears but then fast disappears, so I do not see what it writes. what can I do?
Post Sat Apr 21, 2012 3:38 pm
Re: IPTV support
run cmd.exe first and then execute the ffmpeg command from that window
o.neill
Post Sat Apr 21, 2012 7:19 pm
Re: IPTV support
OH THANKS.. there is printscreen:
Return to Feature requests
