[SOLVED] Serviio 1.9 HLS redirection error
cina
Post Mon Aug 28, 2017 8:18 pm
Hi!
Before 1.9 I had nginx redirection set up and all was working as expected. Redirection was configured through https (443) ports.
With version 1.9 video playback is not working. HTML5 player is complaining about that the video file was not found. Chrome DevTools log shows that Mixed Content was served with XMLHttpRequest. The item containing HLS-0 in its path requests a http item not https.
Is that by design? Can it be corrected? Any more info needed?
Thank you for your effort.
Zsolt
P.S.: The above situation is usually appearing if the software hard-codes base URI with http:// and not using relative paths exclusively. Is that possible? Can it be corrected? Thx.
Post Wed Aug 30, 2017 11:54 am
Re: Serviio 1.9 HLS redirection error - possible solution
I have fixed this for 1.9.1 (to use relative paths).
cina
Post Tue Jan 30, 2018 2:21 pm
zip wrote:Hi,
Hi! Is there any date planned for the release of 19.1? Any beta yet?
Thank you,
Zsolt.
Post Wed Jan 31, 2018 10:52 am
Re: [SOLVED] Serviio 1.9 HLS redirection error
Beta in a few days
cina
Post Sun Feb 04, 2018 4:38 pm
zip wrote:Beta in a few days
Hi!
Redirection is working fine. No "Media not found" error.
Thank you,
Zsolt.
