High CPU (99%)
lintz
Post Sat Jan 27, 2018 12:30 pm
High CPU (99%)
I'm finding my ServiioService.exe continously running at 99% which causes my PC to run so slow that it's virtually unusable. The high usage can occur even if I don't access serviio on my TV.
I've enabled DEBUG logging to see if there is anything that might explain the high CPU usage but nothing stands out for me.
Has anyone else experienced high CPU usage on ServiioService.exe and if so, what did you do to stop it?
Post Sat Jan 27, 2018 11:45 pm
Re: High CPU (99%)
Is this a new Serviio install? If so, and if you have a large number of media files to index, it could take some time.
lintz
Post Sun Jan 28, 2018 1:53 am
Re: High CPU (99%)
No, not a new installation.
All new media files added are displayed straight away.
Is there anything in the log file that I should look out for?
Post Sun Jan 28, 2018 5:04 am
Re: High CPU (99%)
It isn't the initial display that takes time, it's retrieving online metadata that can take some time. But since it's not a new install, that's probably not it. Zip can answer better what to look for in the log.
lintz
Post Fri Feb 02, 2018 11:28 am
Re: High CPU (99%)
Any ideas?
I've uninstalled and reinstalled but still have the same issue....
Post Sun Feb 04, 2018 1:35 pm
Re: High CPU (99%)
maybe it's stuck on a particular file? check the log (detailed log) to see what is the last file being added and try to move it somewhere else
lintz
Post Mon Feb 05, 2018 1:02 pm
Re: High CPU (99%)
I removed all my shared folders and restarted the Serviio service which seemed to work for about an hour but then noticed my PC CPU was back at 100% (99% was ServiioService.exe).
I looked in the log file again and saw a number of the below entries repeated multiple times.
2018-02-05 22:04:01,647 DEBUG [RendererSearchSender$RendererSearchWorker] Received search response: location: http://192.168.0.222:3457/MediaRenderer.xml, st: urn:schemas-upnp-org:device:MediaRenderer:1
2018-02-05 22:04:01,647 DEBUG [RendererSearchSender$RendererSearchWorker] Received a valid M-SEARCH response from Renderer b713891b-24e9-88a6-d550-12020d9c5041 from address 192.168.0.222
2018-02-05 22:04:01,662 DEBUG [RendererManager] Retrieve device description from http://192.168.0.222:3457/MediaRenderer.xml
192.168.0.222 is the IP of my Netgear WIFI Extender (which is not what my PC is connected to?). Am I right in my interpritation of the logs that the WIFI Extender is sending a message to the Serviio Service to perform a search? If so, how can I stop this?
Post Mon Feb 05, 2018 9:46 pm
Re: High CPU (99%)
Doubt that is your issue (try turning off the extender for a while to test?) but you can also disable the device in the Serviio Status screen.
You are looking for the last media file that was indexed in the log before it started going to 100%.
Post Wed Feb 07, 2018 4:37 pm
Re: High CPU (99%)
Serviio searches for UPnP devices, and the extender is one of them.
chatz
Post Wed Sep 11, 2019 9:18 am
Re: High CPU (99%)
I had the high CPU problem and after a while, I found that it was my VPN (Windscrible) was the problem. I unticked the "Force close all the TCP sockets ...... in the API resolution preferences section. Works OK now
Hope this helps someone.
Great software BTW ;)
chatz
Post Sun Oct 06, 2019 10:22 am
Re: High CPU (99%)
Task manager
Not 100% sure what you are asking
meehaneo
Post Thu May 29, 2025 11:22 am
Re: High CPU (99%)
Thought I would add this - might help someone!
I had the high CPU problem with serviio (Windows 10) and it also turned out to be my VPN (Windscribe). I clicked the option to turn on "Allow LAN Traffic" which allows access to local services and printers while connected to the VPN.
Serviio calmed right down!
Users browsing this forum: Google [Bot] and 68 guests
