codec option & subtitle fix
Hi!
First off, im really happy to see that html5 webplayer is now avaible on serviio, its good to see that the developer does listen to feature requests!!
I've got 2 new feature requests that i personally think would make serviio better:
1. a option to switch the default codec serviio uses for transcoding,
i'd suggest the options to be x264 and x265 - ffmpeg supports x265 too and x265 would save alot of network bandwidth while streaming because the small output sizes.
2. subtitle fix for the mediabrowser html5 player - i've noticed that with movies that have a long runtime (2 hrs) the subtitle will stop working out of nowhere, usually around the middle.
this makes the subtitle feature useless to me and forces me to burn subtitles in movies in order to watch them.
Thanks! and i do apologize if my english looks like garbage, i rushed it.
