Vertically Squashed Video on Sony Bravio KDL-46HX823
ploq
Post Wed Dec 27, 2017 12:42 pm
Hello
I have a Sony Bravia KDL-46HX823 (~6 years old) and I'm using Serviio PRO v 1.9.
70% of the videos I play are fine, however, the rest are substantially squashed vertically (>50%). Serviio is using the "Sony Bravia TV (2011)" profile - I have tried other Sony profiles in the past without improvement. Other (less good at high bit-rates) players like UMS don't suffer this issue.
Help?!
Sean
Post Fri Jan 19, 2018 9:17 am
Re: Vertically Squashed Video on Sony Bravio KDL-46HX823
Does the video play correctly using other profile(s)?
ploq
Post Sun Feb 11, 2018 6:50 pm
The videos in question don't play correctly on any profiles I've tried - I have to play them using UMS. In fact, just lately most new videos don't seem to play unsquashed. I recently reinstalled without any improvement.
ploq
Post Tue Feb 13, 2018 10:30 pm
I've just worked out that burned-in-subtitles cause the squashiness... if I disable burned-in-subtitles (my TV doesn't handle subtitles natively) then it works fine - not squashed. Thing is, I really need the subtitles :/
Post Wed Feb 14, 2018 9:52 pm
Which profile are you using?
ploq
Post Wed Feb 14, 2018 10:08 pm
Hi
This: "Sony Bravia TV (2011)", I've tried others too.
Post Thu Feb 15, 2018 12:53 pm
Have you tried the aspect button on your remote to fix the issue?
When you say "vertically squashed" are you getting black bars on the sides of the video or top and bottom?
If the aspect button doesn't fix it, post MediaInfo for the file you are trying to play.
ploq
Post Sat Mar 03, 2018 7:41 pm
Any video, that's any video, with subtitles available (as SRT) (and with burned-in subtitles (14pt) enabled in the console (delivery->subtitles)) get's squashed to a ~1/2 of the correct vertical size. If I disable hard-coded subtitles then it's ratio is fine. Playing with TV aspect ratio doesn't fix it :/ BIG black bars top and bottom.
This seems to be a dev issue around subtitle rendering on the fly, it seems to be resizing the video to accommodate subtitles.
https://i.imgur.com/EpElU95.jpg
Post Thu Mar 08, 2018 11:51 am
Try this:
  • Edit the file config/profiles.xml using your favourite text editor (I recommend NotePad++)
  • Within the "Sony Bravia TV (2011)" profile add the following:
          <GenericTranscoding>
             <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="384" />
          </GenericTranscoding>
    directly under the line </Transcoding>.
  • Save the file
  • Restart your PC
See if that makes a difference. If not, post Mediainfo details for the file.
ploq
Post Sat Mar 17, 2018 6:12 pm
Your fix did not make any difference.
It's NOT the file... it's any video played with subtitles... So a MediaInfo would serve no purpose.
I played around with Serviio more and the "Sony BDP-Sx100 (2013)" profile fixes the problem, it may introduce other problems though. It would be useful to know what in this wrong profile has fixed the subtitle issue.
Thank you for looking at it in any case.
<Profile id="bdp2013" name="Sony BDP-Sx100 (2013)" extendsProfileId="1">
<DeviceDescription>
<!-- act as WMP so that the TV doesn't show root categories -->
<ModelName>Windows Media Player Sharing</ModelName>
<ModelNumber>3.0</ModelNumber>
<Manufacturer>Microsoft Corporation</Manufacturer>
</DeviceDescription>
<ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.SonyDLNAMessageBuilder</ContentDirectoryMessageBuilder>
<ContentDirectoryDefinitionFilter>org.serviio.upnp.service.contentdirectory.definition.WMPContentDirectoryDefinitionFilter</ContentDirectoryDefinitionFilter>
<MediaFormatProfiles>
<!-- rename 3gp profiles that can be played as AVC -->
<MediaFormatProfile mime-type="video/mp4" name="AVC_MP4_MP_SD_AAC_MULT5">AVC_3GPP_BL_QCIF15_AAC</MediaFormatProfile>
</MediaFormatProfiles>
<H264LevelCheck>FILE_ATTRIBUTES</H264LevelCheck>
<!-- For dvr-ms files force mpeg2video transcoding to fix monotone timestamps problems -->
<Video targetContainer="mpegts" targetACodec="ac3" forceVTranscoding="true" forceInheritance="true">
<Matches container="asf" vCodec="mpeg2video" />
<Matches container="asf" vCodec="mpeg1video" />
<!-- h264 videos with high/main profile level > 4.2 will be transcoded to mpegts with mpeg2video and ac3 audio -->
<Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="320" forceInheritance="true">
<Matches container="*" vCodec="h265"/>
<Matches container="*" vCodec="h264" profile="high_10" />
<Matches container="*" vCodec="h264" profile="high_444" />
<Matches container="*" vCodec="h264" profile="high_422" />
<Matches container="*" vCodec="h264" profile="high" levelGreaterThan="4.2" />
<Matches container="*" vCodec="h264" profile="main" levelGreaterThan="4.2" />
<Matches container="matroska" vCodec="vp9" />
<Video targetContainer="mpegts" forceInheritance="true">
<!-- unsupported codecs will be transcoded to mpegts with mpeg2video and ac3 audio -->
<Matches container="flv" />
<Matches container="wtv" />
<Matches container="ogg" />
<Matches container="rm" />
<!-- digital camera video formats -->
<Matches container="mp4" vCodec="dvvideo" />
<Audio targetContainer="lpcm" forceInheritance="true">
<!-- To allow "pause" then "resume" functions and album art for TVs that support it - transcode to mp3 instead -->
<Matches container="mp3" codec="mp2" />
<Matches container="wv" />
<Matches container="mpc" />
<Matches container="ape" />
<Matches container="dsf" />
<Matches container="mp4" codec="alac" />
</Audio>
<OnlineTranscoding>
<!-- do not transcode to ac3 -->
<Matches container="mp4" />
<Matches container="applehttp" vCodec="h264" />
<Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="320" forceInheritance="true">
<Matches container="asf" /> <!-- to support mms:// streams -->
</OnlineTranscoding>
<AudioTrackRemux>
<Matches container="*" vCodec="h264" />
<Matches container="*" vCodec="mpeg2video" />
<Matches container="*" vCodec="mpeg1video" />
<Matches container="*" vCodec="mpeg4" />
<Matches container="*" vCodec="msmpeg4" />
</AudioTrackRemux>
<Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" maxVBitrate="17000" aBitrate="320" />
ploq
Post Sun Apr 08, 2018 8:10 pm
The profile that fixes the subtitle bug introduces instances of stutter and audio silence/dislocation. I've now given up on Serviio and switched to Universal Media Server v7.0
Thanks anyway.
CLOSED
Users browsing this forum: No registered users and 55 guests
