servioo do not start .
thierry
Post Thu Feb 15, 2018 7:49 am
Hello
I use servioo for many years with an old XP compatible version
I just changed computers with winfows 10 and I just installed the latest version of servioo.
I encounter a problem because servioo does not start automatically when windows starts, on the other hand no icon appears on icon tray
the service is installed
Thank you for your help
thierry
Post Thu Feb 15, 2018 1:21 pm
Re: servioo do not start .
There is no longer a System Tray icon for Serviio, so don't use that as an indicator that Serviio isn't starting. I am assuming it is not appearing in your players. Please provide a copy of your Serviio log so we can look at the startup functions.
Post Thu Feb 15, 2018 1:23 pm
As above... To see if Serviio is running type http://localhost:23423/console in your web browser on the PC that Serviio is installed. If that says the site cannot be reached then Serviio is indeed not running and you will need to post the log as suggested above.
Users browsing this forum: Google [Bot] and 32 guests
