problem move forward mp4
hnera
Post Sat Feb 17, 2018 9:44 pm
with some mp4 files not fast forward why?
my tv ue55f6800sd
my O.S kubuntu 17.10
Post Sat Feb 17, 2018 10:14 pm
Re: problem move forward mp4
Fast forward will not work if the file is being transcoded. Can you post the media info for a file that FF works and one that doesn't? And which profile are you using for your TV?
hnera
Post Fri Feb 23, 2018 6:24 pm
atc98092 wrote:Fast forward will not work if the file is being transcoded. Can you post the media info for a file that FF works and one that doesn't? And which profile are you using for your TV?
THX resolved by turning off transcoding
thank you
