Is temp folder property respected?
student975
Post Sun Feb 18, 2018 4:27 pm
Hi!
I have set temporary folder property:
>>> sudo ps aux | grep java | grep serviio
root     11046 17.8  6.3 2915220 253296 ?      Sl   19:17   0:17 java -Xmx384M -Djava.net.preferIPv4Stack=true -Djava.awt.headless=true -Dderby.system.home=/usr/share/java/serviio/library -Dserviio.home=/usr/share/java/serviio -Dffmpeg.location=ffmpeg -Dserviio.defaultTranscodeFolder=/data/sys/tmp -classpath /usr/share/java/serviio/lib/*:/usr/share/java/serviio/config org.serviio.MediaServer
Also, 777 for that folder:
>>> ls -als /data/sys/tmp/
total 1
1 drwxrwxrwx 2 root root 2 Feb 18 18:47  .
Nevertheless Serviio uses
/tmp
(which is mapped to RAM and, as result, is fatal for NAS).
What have I missed?
(1.9 is in use as the last in AUR)
Post Sun Feb 18, 2018 4:47 pm
Re: Is temp folder property respected?
Did you set the temp location in the Serviio console? It's under the transcoding settings. Serviio uses it properly for me, and I have altered the location.
student975
Post Sun Feb 18, 2018 6:35 pm
I have got information from wiki. Yes, your way (that is via console) seems to work, thanks!
Still interested in the original question if JAVA_OPT parameters are respected.
Post Sun Feb 18, 2018 6:55 pm
student975 wrote:I have got information from wiki. Yes, your way (that is via console) seems to work, thanks!
Developer will have to answer that question, unless he's answered it for someone else and they can provide the answer.
Post Mon Feb 19, 2018 9:55 am
here's more info: http://serviio.org/index.php?option=com ... icle&id=43
I think this is the default value before you override it via the console setting. So used just after your first install.
student975
Post Mon Feb 19, 2018 5:22 pm
zip wrote:here's more info: http://serviio.org/index.php?option=com ... icle&id=43
I guess it would be useful to mention settings priority somewhere in that referred article. Or, more strictly, to say the property is respected until the first Save click in the console.
Users browsing this forum: Baidu [Spider] and 31 guests
