error in mediabrowser "hlsjs video file not found"
coredump
Post Fri Feb 23, 2018 9:27 am
Re: error in mediabrowser "hlsjs video file not found"
error shows up instantanously, browser cache already cleaned up, using either
Firefox 52.6.0 (64-Bit) esr
Google Chrome 63.0.3239.132 (Offizieller Build) (64-Bit) (cohort: Stable)
Post Fri Feb 23, 2018 2:41 pm
ok, that would seem it's related to the transcoding job. Can you post detailed log of when you're trying to play the file?
bunkerman
Post Thu Mar 01, 2018 7:06 pm
update to 1.9.1 did not fix the error in mediabrowser "hlsjs video file not found"
can i tune something, so i won't get the error/timeout? is it because of the low fi hw i'm using(synology 413j)?
Post Thu Mar 01, 2018 7:39 pm
how long does it take to get this error from the moment you hit play? I think I increased it to 60 seconds.
bunkerman
Post Fri Mar 02, 2018 7:45 am
after exactly 1 min. i get "500 Internal Server Error"
coredump
Post Fri Mar 02, 2018 8:47 am
so as soon I try to play I get
2018-03-02 09:41:11,172 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target ssdp:all from address /192.168.100.77:45696s
2018-03-02 09:41:11,172 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.100.77
2018-03-02 09:41:11,172 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /192.168.100.77:45696
2018-03-02 09:41:13,940 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 131)
2018-03-02 09:41:13,940 WARN [OnlineItemService] Cannot find online repository with id 131
2018-03-02 09:41:13,940 WARN [CDSBrowseServerResource] Object with id V_OF^FOL*$OI10000013170001685 doesn't exist
2018-03-02 09:41:13,941 WARN [ServiioStatusService] HttpCodeException occurred. Returning error code 404 to the REST layer. Message: null
org.serviio.restlet.HttpCodeException
at org.serviio.upnp.service.contentdirectory.rest.resources.server.CDSBrowseServerResource.browse(CDSBrowseServerResource.java:92)
at sun.reflect.GeneratedMethodAccessor24.invoke(Unknown Source)
at org.restlet.resource.ServerResource.doHandle(ServerResource.java:524)
at org.restlet.resource.ServerResource.get(ServerResource.java:743)
at org.restlet.resource.ServerResource.doHandle(ServerResource.java:618)
at org.restlet.resource.ServerResource.doNegotiatedHandle(ServerResource.java:679)
at org.restlet.resource.ServerResource.doConditionalHandle(ServerResource.java:357)
at org.serviio.restlet.AbstractServerResource.doConditionalHandle(AbstractServerResource.java:49)
at org.serviio.restlet.AbstractProEditionServerResource.doConditionalHandle(AbstractProEditionServerResource.java:35)
at org.serviio.upnp.service.contentdirectory.rest.resources.server.AbstractCDSServerResource.doConditionalHandle(AbstractCDSServerResource.java:59)
at org.serviio.upnp.service.contentdirectory.rest.resources.server.AbstractRestrictedCDSServerResource.doConditionalHandle(AbstractRestrictedCDSServerResource.java:58)
at org.restlet.resource.ServerResource.handle(ServerResource.java:1014)
at org.serviio.upnp.service.contentdirectory.rest.resources.server.CDSBrowseServerResource.handle(CDSBrowseServerResource.java:124)
at org.restlet.resource.Finder.handle(Finder.java:246)
at org.restlet.routing.Filter.doHandle(Filter.java:159)
at org.restlet.routing.Filter.handle(Filter.java:206)
at org.restlet.routing.Router.doHandle(Router.java:431)
at org.restlet.routing.Router.handle(Router.java:648)
at org.restlet.engine.application.StatusFilter.doHandle(StatusFilter.java:155)
at org.restlet.engine.CompositeHelper.handle(CompositeHelper.java:211)
at org.restlet.engine.application.ApplicationHelper.handle(ApplicationHelper.java:84)
at org.restlet.Application.handle(Application.java:384)
at org.restlet.Component.handle(Component.java:406)
at org.restlet.Server.handle(Server.java:516)
at org.restlet.engine.connector.ServerHelper.handle(ServerHelper.java:72)
at org.restlet.engine.adapter.HttpServerHelper.handle(HttpServerHelper.java:152)
at org.restlet.ext.simple.internal.SimpleContainer.handle(SimpleContainer.java:80)
at org.simpleframework.http.core.Dispatcher.dispatch(Dispatcher.java:121)
at org.simpleframework.http.core.Dispatcher.run(Dispatcher.java:103)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
2018-03-02 09:41:15,453 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 109563)
2018-03-02 09:41:15,453 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2018-03-02 09:41:19,851 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 109563)
2018-03-02 09:41:19,852 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2018-03-02 09:41:21,172 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target ssdp:all from address /192.168.100.77:45696s
2018-03-02 09:41:21,172 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.100.77
2018-03-02 09:41:21,172 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /192.168.100.77:45696
2018-03-02 09:41:21,818 DEBUG [CDSRetrieveMediaServerResource] GET http://www.hottar.de:23424/cds/resource ... diaBrowser HTTP/1.1, headers = [host: www.hottar.de:23424,user-agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:52.0) Gecko/20100101 Firefox/52.0,accept: */*,accept-language: de,en-US;q=0.7,en;q=0.3,accept-encoding: gzip, deflate,referer: http://www.hottar.de:23424/mediabrowser/,cookie: _ga=GA1.2.1429782928.1482399207,connection: keep-alive]
2018-03-02 09:41:21,819 DEBUG [CDSRetrieveMediaServerResource] Creating client with id '192.168.100.100' and name 'MediaBrowser'
2018-03-02 09:41:21,819 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.100.100, Profile=HTML5, Name=MediaBrowser'
2018-03-02 09:41:21,820 DEBUG [ResourceDeliveryProcessor] Request for resource 10000013170001685 and type 'MANIFEST' received
2018-03-02 09:41:21,820 DEBUG [ManifestRetrievalStrategy] Retrieving info of Manifest for media item with id 10000013170001685
2018-03-02 09:41:21,821 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 10000013170001685 (online)
2018-03-02 09:41:21,822 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 131)
2018-03-02 09:41:21,822 WARN [OnlineItemService] Cannot find online repository with id 131
2018-03-02 09:41:21,822 WARN [ResourceDeliveryProcessor] Error while processing resource, sending back 404 error. Message: Media item 10000013170001685 cannot be found
2018-03-02 09:41:21,822 WARN [ServiioStatusService] HttpCodeException occurred. Returning error code 404 to the REST layer. Message: null
at org.serviio.upnp.service.contentdirectory.rest.resources.server.CDSRetrieveMediaServerResource.deliver(CDSRetrieveMediaServerResource.java:96)
2018-03-02 09:41:22,875 DEBUG [SearchManager] Committing search index
2018-03-02 09:41:24,922 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 109563)
2018-03-02 09:41:24,922 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
Scanning however looks OK:
2018-03-02 09:44:37,196 DEBUG [ActionsServerResource] Action with name 'checkStreamUrl' was requested
2018-03-02 09:44:37,196 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: http://daserste_live-lh.akamaihd.net/i/ ... aster.m3u8
2018-03-02 09:44:37,196 DEBUG [ProcessExecutor] Starting /usr/local/bin/ffmpeg/ffmpeg -analyzeduration 10000000 -i http://daserste_live-lh.akamaihd.net/i/ ... aster.m3u8
2018-03-02 09:44:39,806 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 109563)
2018-03-02 09:44:39,806 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2018-03-02 09:44:40,073 DEBUG [FFmpegMetadataRetriever] Retrieving H264 profile/level for file 'http://daserste_live-lh.akamaihd.net/i/daserste_de@91204/master.m3u8'
2018-03-02 09:44:40,073 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve H264 header for file: http://daserste_live-lh.akamaihd.net/i/ ... aster.m3u8
2018-03-02 09:44:40,073 DEBUG [ProcessExecutor] Starting /usr/local/bin/ffmpeg/ffmpeg -analyzeduration 10000000 -i http://daserste_live-lh.akamaihd.net/i/ ... aster.m3u8 -frames:v 1 -c:v copy -f h264 -an pipe:
2018-03-02 09:44:41,172 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target ssdp:all from address /192.168.100.77:45696s
2018-03-02 09:44:41,173 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.100.77
2018-03-02 09:44:41,173 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /192.168.100.77:45696
2018-03-02 09:44:42,142 DEBUG [FFmpegMetadataRetriever] File 'http://daserste_live-lh.akamaihd.net/i/daserste_de@91204/master.m3u8' has H264 profile MAIN, levels [{RF=1.2, H=3.1}] and 3 ref frames
2018-03-02 09:44:44,959 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 109563)
2018-03-02 09:44:44,959 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2018-03-02 09:44:49,860 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 109563)
2018-03-02 09:44:49,860 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2018-03-02 09:44:51,172 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target ssdp:all from address /192.168.100.77:45696s
2018-03-02 09:44:51,173 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.100.77
2018-03-02 09:44:51,173 DEBUG [DiscoverySearchResponder] Sending 6 M-SEARCH response message(s) to /192.168.100.77:45696
Post Sun Mar 04, 2018 10:03 pm
coredump
it's an online stream, right? how many streams / feed have you had? more than 1 thousand?
coredump
Post Fri Mar 09, 2018 9:49 am
zip wrote:coredump
Correct this one is German Live TV ARD stream. Currently I have 62 web ressources (working) and 4 live streams (none of them currently functional)
coredump
Post Mon Apr 30, 2018 2:22 pm
Any update on above issue? Anything I should provide?
Previous
Users browsing this forum: Baidu [Spider], Google [Bot] and 26 guests
