MediaBrowser problem after update 1.9.1
Failure detected just after upgrade of Serviio 1.9.1 , in two computers, W7 and W10, with internet explorer, and same problem accessing locally on the serviio computer or remotelly.
josch.hh wrote:I also not able to use Mediabrowser.
I simply can't get in. I enter the password and nothing happens, it jumps but the login screen.
I already cleared all browser cache and stuff. I change the password in the console. Not effect.
Anyone can help?
eperezsal wrote:I have Pro.
eperezsal wrote:Are you refering to my problem after upgrade with IE, not failing with Chrome, or , to the problem of not being able to open MediaBrowser (not my case, and not the reason of the thread).Cheers.
Users browsing this forum: Google [Bot] and 213 guests
