How disable subtitle?
Scoty
Post Sat Feb 24, 2018 10:24 am
I have install latest 1.91 and dont have activate subtitle but i get subtitle on every Video. How can i deactivate now? Use a Sony XE93 TV
Post Thu Mar 01, 2018 11:59 am
Re: How disable subtitle?
Check your subtitle settings in Serviio Console?
Post MediaInfo for the file.
Scoty
Post Sun Mar 04, 2018 3:53 pm
Bitgid wrote:Hey,try this one,
You have to press the "Tools" button on the remote while the movie is playing. That brings up a menu that contains all display options, including close captioning, font, color, etc.
or
tv`s option and setting, find where you choose font size, there you can disable them completely. (i am talking about E serie, but your should be similar...)
Regards
Bitgid ;)
Working thanks
Users browsing this forum: No registered users and 232 guests
