1.9.1 and lost Serviio system properties/profiles
Paul C
Post Mon Feb 19, 2018 2:23 pm
Installed 1.9.1 and all running well.
However I lost the recent tweaks for better artwork i.e. serviio.hdThumbnailResolution and serviio.socketBuffer.
I also lost a profile "Generic HD profile" that I had created (a copy of the Generic DLNA profile with Thumbnail set to "HD").
I have reinstalled them and all is well.
Is there a procedure for correctly installing new versions which overcomes this issue?
Post Mon Feb 19, 2018 3:42 pm
Re: 1.9.1 and lost Serviio system properties/profiles
No. It'll override the vmoptions file. It should crearte a profiles.xml.bak file though, so that you can copy over the profile. You can also move this profile into user-profiles.xml which is not touched during installation.
Paul C
Post Sat Feb 24, 2018 12:12 pm
zip wrote:No. It'll override the vmoptions file. It should crearte a profiles.xml.bak file though, so that you can copy over the profile. You can also move this profile into user-profiles.xml which is not touched during installation.
Thanks. I'll back up the vmoptions file prior to future updates, and set-up my Generic HD profile in user profiles.
Users browsing this forum: No registered users and 232 guests
