Thumbnails mostly black
Conq
Post Sun Dec 10, 2017 9:21 pm
I have recently upgraded Serviio.
I run it on my NAS, so manually upgraded serviio to 1.9, Java to 1.8.0_151 and ffmpeg to 3.2.7.
After the upgrade I did a complete reload of my file library and since then most of my thumbnails have turned black. I mean less than 1% of the thumbnails have a picture, so it is not completely broken, which just makes it even more confusing.
I tried to turn on debugging and all seems fine according to the log. Here is a part. I edited it to remove the stuff that does not seem relevant.
2017-12-10 20:30:09,100 DEBUG [MediaFileIndexer] Found file '/i-data/61b4ff00/Volume6/video/movies/Bicycle Thieves (1948)/Bicycle Thieves.mkv', checking if it's already in the Library
2017-12-10 20:30:09,100 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item /i-data/61b4ff00/Volume6/video/movies/Bicycle Thieves (1948)/Bicycle Thieves.mkv
2017-12-10 20:30:09,101 DEBUG [MediaItemDAOImpl] Looking up a media item for file path: /i-data/61b4ff00/Volume6/video/movies/Bicycle Thieves (1948)/Bicycle Thieves.mkv, ignore case: false
2017-12-10 20:30:09,103 DEBUG [MediaItemDAOImpl] Media item /i-data/61b4ff00/Volume6/video/movies/Bicycle Thieves (1948)/Bicycle Thieves.mkv doesn't exist in DB yet
2017-12-10 20:30:09,103 DEBUG [MediaFileIndexer] File not in Library, will add it
2017-12-10 20:30:09,104 DEBUG [LibraryHelper] Checking if the file is complete using file lock
2017-12-10 20:30:09,119 DEBUG [VideoExtractionStrategy] Extracting metadata of video file: /i-data/61b4ff00/Volume6/video/movies/Bicycle Thieves (1948)/Bicycle Thieves.mkv
2017-12-10 20:30:09,150 DEBUG [LibraryOneTimeScanner] Looking for files to share in folder: /i-data/bc21882c/Volume2/video/series/The Blacklist/The Blacklist S01
2017-12-10 20:30:09,152 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: /i-data/61b4ff00/Volume6/video/movies/Bicycle Thieves (1948)/Bicycle Thieves.mkv
2017-12-10 20:30:09,153 DEBUG [ProcessExecutor] Starting ffmpeg -i /i-data/61b4ff00/Volume6/video/movies/Bicycle Thieves (1948)/Bicycle Thieves.mkv
2017-12-10 20:30:09,364 DEBUG [FFmpegMetadataRetriever] Retrieving H264 profile/level for file '/i-data/61b4ff00/Volume6/video/movies/Bicycle Thieves (1948)/Bicycle Thieves.mkv'
2017-12-10 20:30:09,364 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve H264 header for file: /i-data/61b4ff00/Volume6/video/movies/Bicycle Thieves (1948)/Bicycle Thieves.mkv
2017-12-10 20:30:09,370 DEBUG [ProcessExecutor] Starting ffmpeg -i /i-data/61b4ff00/Volume6/video/movies/Bicycle Thieves (1948)/Bicycle Thieves.mkv -frames:v 1 -c:v copy -f h264 -bsf:v h264_mp4toannexb -an pipe:
2017-12-10 20:30:09,655 DEBUG [FFmpegMetadataRetriever] File '/i-data/61b4ff00/Volume6/video/movies/Bicycle Thieves (1948)/Bicycle Thieves.mkv' has H264 profile MAIN, levels [{RF=3.1, H=3.1}] and 3 ref frames
2017-12-10 20:30:09,709 DEBUG [OpenSubtitlesService] Generating hash code for opensubtitles.org for file Bicycle Thieves.mkv
2017-12-10 20:30:09,806 DEBUG [MetadataExtractionCoordinator] Metadata found via extractor EMBEDDED: VideoMetadata [title=Bicycle Thieves, filePath=/i-data/61b4ff00/Volume6/video/movies/Bicycle Thieves (1948)/Bicycle Thieves.mkv, fileSize=644470343, audioTracks=1/AC3/384/6/48000/eng/true, bitrate=2070, container=MATROSKA, contentType=UNKNOWN, rating=null, duration=2490, episodeNumber=null, fps=23.976, h264Levels={RF=3.1, H=3.1}, h264Profile=MAIN, ftyp=null, height=720, seasonNumber=null, seriesName=null, timestampType=null, videoBitrate=null, videoCodec=H264, videoFourCC=null, videoStreamIndex=0, width=1280, embeddedSubtitles=[2/SRT/dan/true, 3/SRT/nor/false]]
2017-12-10 20:30:09,831 DEBUG [LibraryOneTimeScanner] Looking for files to share in folder: /i-data/bc21882c/Volume2/video/series/The 100/The 100 S02
2017-12-10 20:30:09,854 DEBUG [TheMovieDBSourceAdaptor] Searching for 'bicycle thieves' 1948 (language: en)
2017-12-10 20:30:10,181 DEBUG [TheMovieDBSourceAdaptor] Found 1 matches
2017-12-10 20:30:10,181 DEBUG [TheMovieDBSourceAdaptor] Searching for 'bicycle thieves' 1948 (language: en)
2017-12-10 20:30:10,307 DEBUG [TheMovieDBSourceAdaptor] Found 1 matches
2017-12-10 20:30:10,308 DEBUG [TheMovieDBSourceAdaptor] Found a suitable match, id = 5156
2017-12-10 20:30:10,317 DEBUG [TheMovieDBSourceAdaptor] Retrieving details of movie (movieId = 5156, language = en)
2017-12-10 20:30:11,357 DEBUG [TheMovieDBSourceAdaptor] Retrieved poster: http://image.tmdb.org/t/p/w500/a8OKLrk1H9S5yaFKUqSMkyP4FRb.jpg
2017-12-10 20:30:11,359 DEBUG [MetadataExtractionCoordinator] Metadata found via extractor ONLINE_VIDEO_SOURCES: VideoMetadata [title=Ladri di biciclette, filePath=null, fileSize=0, audioTracks=, bitrate=null, container=null, contentType=MOVIE, rating=8.1, duration=null, episodeNumber=null, fps=null, h264Levels={}, h264Profile=null, ftyp=null, height=null, seasonNumber=null, seriesName=null, timestampType=null, videoBitrate=null, videoCodec=null, videoFourCC=null, videoStreamIndex=null, width=null, embeddedSubtitles=[]]
2017-12-10 20:30:11,377 DEBUG [XBMCExtractor] Checking if file 'Bicycle Thieves.nfo' is a XBMC NFO file
2017-12-10 20:30:11,459 DEBUG [XBMCExtractor] File 'Bicycle Thieves.nfo' is a valid XBMC file
2017-12-10 20:30:11,460 DEBUG [XBMCExtractor] Found XBMC NFO file Bicycle Thieves.nfo. Will try to extract metadata from it.
2017-12-10 20:30:11,566 DEBUG [XBMCExtractor] Parsing NFO file for movie metadata
2017-12-10 20:30:12,296 DEBUG [MetadataExtractionCoordinator] Metadata found via extractor XBMC: VideoMetadata [title=Bicycle Thieves, filePath=null, fileSize=0, audioTracks=, bitrate=null, container=null, contentType=MOVIE, rating=8.1, duration=null, episodeNumber=null, fps=null, h264Levels={}, h264Profile=null, ftyp=null, height=null, seasonNumber=null, seriesName=null, timestampType=null, videoBitrate=null, videoCodec=null, videoFourCC=null, videoStreamIndex=null, width=null, embeddedSubtitles=[]]
2017-12-10 20:30:12,325 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2017-12-10 20:30:12,327 DEBUG [CoverImageInFolderExtractor] Found cover image Bicycle Thieves-poster.jpg
2017-12-10 20:30:12,345 DEBUG [MetadataExtractionCoordinator] Metadata found via extractor COVER_IMAGE_IN_FOLDER: VideoMetadata [title=null, filePath=null, fileSize=0, audioTracks=, bitrate=null, container=null, contentType=null, rating=null, duration=null, episodeNumber=null, fps=null, h264Levels={}, h264Profile=null, ftyp=null, height=null, seasonNumber=null, seriesName=null, timestampType=null, videoBitrate=null, videoCodec=null, videoFourCC=null, videoStreamIndex=null, width=null, embeddedSubtitles=[]]
2017-12-10 20:30:12,381 DEBUG [VideoService] Adding video into database: Bicycle Thieves
2017-12-10 20:30:12,396 DEBUG [FolderDAOImpl] Looking for folder hierarchy movies/Bicycle Thieves (1948)
2017-12-10 20:30:13,365 DEBUG [CoverImageService] Resizing and storing cover art image for max resolution of 320x320
2017-12-10 20:30:13,378 DEBUG [ImageUtils] Starting image resize, size = 277150 bytes
2017-12-10 20:30:15,691 DEBUG [RendererSearchSender] Searching for Renderer devices
2017-12-10 20:30:15,700 DEBUG [RendererSearchSender$RendererSearchWorker] Multicasting SSDP M-SEARCH using interface bond0 (bond0) and address 192.168.1.64, timeout = 0
2017-12-10 20:30:15,701 DEBUG [RendererSearchSender$RendererSearchWorker] Sending 1 'm-search' messages
2017-12-10 20:30:15,702 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.64:42348s
2017-12-10 20:30:15,710 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.64:42348s
2017-12-10 20:30:15,720 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.64:42348s
2017-12-10 20:30:17,339 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2017-12-10 20:30:20,523 DEBUG [ImageUtils] Returning resized image, size = 15083 bytes
2017-12-10 20:30:20,524 DEBUG [CoverImageService] Image successfully resized
2017-12-10 20:30:20,524 DEBUG [CoverImageService] Resizing and storing cover art image for max resolution of 160x160
2017-12-10 20:30:20,524 DEBUG [ImageUtils] Starting image resize, size = 15083 bytes
2017-12-10 20:30:20,597 DEBUG [ImageUtils] Returning resized image, size = 907 bytes
2017-12-10 20:30:20,598 DEBUG [CoverImageService] Image successfully resized
2017-12-10 20:30:20,606 DEBUG [CoverImageDAOImpl] Creating a new ImageCover (length = 907)
2017-12-10 20:30:20,967 DEBUG [VideoDAOImpl] Creating a new Video (title = Bicycle Thieves)
2017-12-10 20:30:22,307 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2017-12-10 20:30:21,709 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2017-12-10 20:30:24,392 DEBUG [PersonDAOImpl] Adding a Person Vittorio De Sica to media item 11425 as DIRECTOR
2017-12-10 20:30:24,393 DEBUG [PersonDAOImpl] Reading a Person (name = Vittorio De Sica)
2017-12-10 20:30:24,482 DEBUG [PersonDAOImpl] Creating a new Person (name = Vittorio De Sica)
2017-12-10 20:30:24,588 DEBUG [PersonDAOImpl] Checking if person 30827 has a role DIRECTOR for media item 11425
2017-12-10 20:30:25,089 DEBUG [PersonDAOImpl] Adding a Person Giuseppe Amato to media item 11425 as PRODUCER
2017-12-10 20:30:25,089 DEBUG [PersonDAOImpl] Reading a Person (name = Giuseppe Amato)
2017-12-10 20:30:25,092 DEBUG [PersonDAOImpl] Creating a new Person (name = Giuseppe Amato)
2017-12-10 20:30:25,130 DEBUG [PersonDAOImpl] Checking if person 30828 has a role PRODUCER for media item 11425
2017-12-10 20:30:25,188 DEBUG [PersonDAOImpl] Adding a Person Vittorio De Sica to media item 11425 as PRODUCER
2017-12-10 20:30:25,188 DEBUG [PersonDAOImpl] Reading a Person (name = Vittorio De Sica)
2017-12-10 20:30:25,191 DEBUG [PersonDAOImpl] Checking if person 30827 has a role PRODUCER for media item 11425
2017-12-10 20:30:25,230 DEBUG [PersonDAOImpl] Adding a Person Lamberto Maggiorani to media item 11425 as ACTOR
2017-12-10 20:30:25,230 DEBUG [PersonDAOImpl] Reading a Person (name = Lamberto Maggiorani)
2017-12-10 20:30:25,244 DEBUG [PersonDAOImpl] Creating a new Person (name = Lamberto Maggiorani)
2017-12-10 20:30:25,280 DEBUG [PersonDAOImpl] Checking if person 30829 has a role ACTOR for media item 11425
2017-12-10 20:30:25,371 DEBUG [PersonDAOImpl] Adding a Person Enzo Staiola to media item 11425 as ACTOR
2017-12-10 20:30:25,372 DEBUG [PersonDAOImpl] Reading a Person (name = Enzo Staiola)
2017-12-10 20:30:25,375 DEBUG [PersonDAOImpl] Creating a new Person (name = Enzo Staiola)
2017-12-10 20:30:25,405 DEBUG [PersonDAOImpl] Checking if person 30830 has a role ACTOR for media item 11425
2017-12-10 20:30:25,455 DEBUG [PersonDAOImpl] Adding a Person Lianella Carell to media item 11425 as ACTOR
2017-12-10 20:30:25,455 DEBUG [PersonDAOImpl] Reading a Person (name = Lianella Carell)
2017-12-10 20:30:25,460 DEBUG [PersonDAOImpl] Creating a new Person (name = Lianella Carell)
2017-12-10 20:30:25,488 DEBUG [PersonDAOImpl] Checking if person 30831 has a role ACTOR for media item 11425
2017-12-10 20:30:25,530 DEBUG [PersonDAOImpl] Adding a Person Gino Saltamerenda to media item 11425 as ACTOR
2017-12-10 20:30:25,530 DEBUG [PersonDAOImpl] Reading a Person (name = Gino Saltamerenda)
2017-12-10 20:30:25,535 DEBUG [PersonDAOImpl] Creating a new Person (name = Gino Saltamerenda)
2017-12-10 20:30:27,211 DEBUG [GenreDAOImpl] Reading a Genre (name = Drama)
2017-12-10 20:30:27,260 DEBUG [GenreService] Genre Drama found
2017-12-10 20:30:27,260 DEBUG [GenreDAOImpl] Adding a new Media Item to Genre (media item = 11425, genre = 1)
2017-12-10 20:30:27,308 DEBUG [MediaItemDAOImpl] Getting counts of media items by type
2017-12-10 20:30:27,433 DEBUG [MetadataDescriptorDAOImpl] Creating a new MetadataDescriptor (type = COVER_IMAGE_IN_FOLDER, mediaItemId = 11425)
2017-12-10 20:30:27,647 DEBUG [MetadataDescriptorDAOImpl] Creating a new MetadataDescriptor (type = XBMC, mediaItemId = 11425)
2017-12-10 20:30:27,705 DEBUG [MetadataDescriptorDAOImpl] Creating a new MetadataDescriptor (type = ONLINE_VIDEO_SOURCES, mediaItemId = 11425)
2017-12-10 20:30:27,738 DEBUG [MetadataDescriptorDAOImpl] Creating a new MetadataDescriptor (type = EMBEDDED, mediaItemId = 11425)
2017-12-10 20:30:27,858 DEBUG [CoverImageDAOImpl] Reading a CoverImage for folder (id = 2833)
2017-12-10 20:30:27,958 DEBUG [CoverImageDAOImpl] Reading a CoverImage for folder (id = 1628)
2017-12-10 20:30:28,000 INFO  [SearchManager] Starting up search engine
Has anyone else encountered this problem and might have a hint to where I should look to fix it? Thanks
Post Thu Dec 14, 2017 4:34 pm
Re: Thumbnails mostly black
don't you have some (potentially hidden) images in the folders where your files are? like folder.jpg, etc. They would be used with preference.
Conq
Post Fri Dec 15, 2017 11:31 am
zip wrote:don't you have some (potentially hidden) images in the folders where your files are? like folder.jpg, etc. They would be used with preference.
In the log it says:
That file looks fine.
I can also see a hidden folder called ".thumbs". Is that one serviio makes?
In there I have 3 files: "Bicycle Thieves.mkv.jpg", "Bicycle Thieves-fanart.jpg.jpg" and "Bicycle Thieves-poster.jpg.jpg". They all look fine.
Post Fri Dec 15, 2017 3:47 pm
no, Serviio doesn't make it. It's probably Windows.
Conq
Post Mon Dec 18, 2017 5:53 pm
zip wrote:no, Serviio doesn't make it. It's probably Windows.
Its probably the program I use to make the .nfo files then.
No idea what can cause the black thumbnails?
Edit: Solved the .thumb folder mystery. Its apparantly a feature of myZYXELcloud. Turned it off.
Conq
Post Sat Jan 13, 2018 5:38 pm
To get the ball rolling on this on, is there anyway to debug a little further?
Is there a command I can execute to see if it's some external program that's the problem?
Someway I can check the images in the database maybe?
Anything? :D
Post Mon Jan 15, 2018 8:49 am
This is a bit weird in the log
The HD thumbnail is resized to 15kb, the standard 160x160 is then further resized but end up 907b, which seems very small.
Resizing is done by Java, so not sure. You could update your profile to use HD thumbnails (see the XboxOne profile for example).
Conq
Post Sun Feb 25, 2018 5:35 pm
zip wrote:This is a bit weird in the log
Didn't work unfortunately.
I tried updating to 1.9.1 and now I get a bunch of the following in the log:
java.lang.ArrayIndexOutOfBoundsException: 0
        at sun.nio.cs.UTF_8$Decoder.decode(UTF_8.java:441)
        at java.lang.StringCoding$StringDecoder.decode(StringCoding.java:153)
        at java.lang.StringCoding.decode(StringCoding.java:193)
        at java.lang.String.<init>(String.java:426)
        at java.lang.String.<init>(String.java:491)
        at java.io.UnixFileSystem.list(Native Method)
        at java.io.File.list(File.java:1122)
        at java.io.File.listFiles(File.java:1286)
        at org.serviio.library.local.metadata.extractor.AbstractLocalFileExtractor.findFileInFolder(AbstractLocalFileExtractor.java:127)
        at org.serviio.library.local.metadata.extractor.XBMCExtractor.getMetadataFile(XBMCExtractor.java:80)
        at org.serviio.library.local.metadata.extractor.MetadataExtractor.extract(MetadataExtractor.java:44)
        at org.serviio.library.local.MetadataExtractionCoordinator.extractMetadata(MetadataExtractionCoordinator.java:64)
        at org.serviio.library.local.indexing.MediaFileIndexer.updateMediaFile(MediaFileIndexer.java:136)
        at org.serviio.library.local.indexing.DefaultLibraryMonitor.fileUpdated(DefaultLibraryMonitor.java:77)
        at org.serviio.library.local.indexing.pipe.PipeManager$PipeProcessingConsumer.lambda$run$0(PipeManager.java:175)
        at java.util.Optional.ifPresent(Optional.java:159)
        at org.serviio.library.local.indexing.pipe.PipeManager$PipeProcessingConsumer.run(PipeManager.java:169)
        at java.lang.Thread.run(Thread.java:748)
or
        at sun.nio.cs.UTF_8$Encoder.encode(UTF_8.java:716)
        at java.lang.StringCoding$StringEncoder.encode(StringCoding.java:304)
        at java.lang.StringCoding.encode(StringCoding.java:344)
        at java.lang.String.getBytes(String.java:918)
        at java.io.FileInputStream.open0(Native Method)
        at java.io.FileInputStream.open(FileInputStream.java:195)
        at java.io.FileInputStream.<init>(FileInputStream.java:138)
        at org.apache.commons.imaging.common.bytesource.ByteSourceFile.getInputStream(ByteSourceFile.java:41)
        at org.apache.commons.imaging.formats.jpeg.JpegUtils.traverseJFIF(JpegUtils.java:52)
        at org.apache.commons.imaging.formats.jpeg.JpegImageParser.readSegments(JpegImageParser.java:181)
        at org.apache.commons.imaging.formats.jpeg.JpegImageParser.readSegments(JpegImageParser.java:269)
        at org.apache.commons.imaging.formats.jpeg.JpegImageParser.getImageInfo(JpegImageParser.java:635)
        at org.apache.commons.imaging.Imaging.getImageInfo(Imaging.java:693)
        at org.apache.commons.imaging.Imaging.getImageInfo(Imaging.java:667)
        at org.apache.commons.imaging.Imaging.getImageInfo(Imaging.java:686)
        at org.serviio.library.local.metadata.extractor.CoverImageInFolderExtractor.retrieveMetadata(CoverImageInFolderExtractor.java:140)
        at org.serviio.library.local.metadata.extractor.AbstractLocalFileExtractor.retrieveMetadata(AbstractLocalFileExtractor.java:87)
        at org.serviio.library.local.metadata.extractor.MetadataExtractor.extract(MetadataExtractor.java:47)
        at org.serviio.library.local.indexing.MediaFileIndexer.addNewMediaFile(MediaFileIndexer.java:77)
        at org.serviio.library.local.indexing.DefaultLibraryMonitor.fileAdded(DefaultLibraryMonitor.java:52)
        at org.serviio.library.local.indexing.pipe.PipeManager$PipeProcessingConsumer.lambda$run$0(PipeManager.java:174)
Could they have anything to do with my problems?
Post Mon Feb 26, 2018 2:30 pm
are those images proper binary files?
What is your Java version?
Conq
Post Mon Feb 26, 2018 8:39 pm
zip wrote:are those images proper binary files?
I should think they are proper binary files. Were examples with the same error, from reading files from www.thetvdb.com as well.
I run "Java 1.8.0_151-Oracle Corporation arm".
Post Tue Feb 27, 2018 1:38 pm
Are you on Synology NAS? I think I've seen this before and it was related to the Java distribution on the NAS.
Conq
Post Wed Feb 28, 2018 9:18 pm
zip wrote:Are you on Synology NAS? I think I've seen this before and it was related to the Java distribution on the NAS.
Zyxel NAS. Fetched the Java dist from the official site.
Will try and upgrade Java this weekend and see if that changes anything.
Post Wed Feb 28, 2018 10:33 pm
maybe there is OpenJDK Java, rather than the Oracle one?
Users browsing this forum: Bing [Bot], Google [Bot] and 70 guests
