Anyone else experiencing high cpu after v1.9.1 upgrade?
mr_manny
Post Sun Feb 25, 2018 11:37 pm
Installed the latest v1.9.1 Serviio on my qnap Model TS-569L
Intel Atom™ 2.13 GHz Dual-core Processor
Flash Memory 512MB DOM
System Memory 3GB
Qnap firmware 4.3.3.0262
JRE 8.131.1
I had been running Serviio v 1.9 64bit for several months now, without any issues.
Now that I've upgraded to v1.9.1, my nas cpu seems to stay over 80% until I cycle my Serviio server.
Anyone else encounter this high cpu load on their NAS?
Does anyone have Serviio v1.9 64bit available?
I would like to uninstall v1.9.1 and revert back to the previous version if possible.
thanks
mr_manny
Post Wed Feb 28, 2018 1:38 pm
Re: Anyone else experiencing high cpu after v1.9.1 upgrade?
My wife discovered the following on her ipad and v1.9.1 mediabrowser.
Unable to go to full-screen from the beginning of a video.
Full-screen is only an option, once the PLAY symbol disappears from the middle of the viewing window.
Unfortunately, this does not occur until 30-40mins into the video.
So your viewing experiences consists of no full-screen, and the PLAY symbol in the center of your video.
no bueno :(
Reached out to Serviio...hoping they can help.
mr_manny
Post Wed Mar 07, 2018 3:14 pm
Back to Serviio v1.9 and wife is Happy again = very good thing.
Thank you Serviio for taking care of me.
Your assistance is appreciated...honest :)
Post Wed Mar 07, 2018 6:08 pm
Sorry I hadn't noticed your posts before. I would have suggested trying a different version of ffmpeg on your NAS, and perhaps changing Java versions. But if reverting to 1.9 keeps everyone happy, terrific! I know that is often the most important factor! :lol:
mr_manny
Post Thu Mar 08, 2018 3:01 pm
No worries.
As long as the wife is happy, all is well :)
MAV
Post Fri Mar 16, 2018 10:50 pm
Was there a fix for 1.9.1 for this issue? I'm experiencing the exact same problem on a Synology box.
mr_manny
Post Sat Mar 17, 2018 2:34 pm
I'm not aware of any fixes/updates.
With Serviio's assistance (providing the v1.9 bits), I was able to revert back to the previous version.
Before performing any updates in the future, I recommend having the previous version saved somewhere...just in case :)
Good Luck
MAV
Post Sun Mar 18, 2018 6:55 pm
I've tried it on a couple of iOS devices, all with the same results. Any advice from the staff would be great.
