Internet Radio - station changes and issues
Paul C
Post Wed Mar 14, 2018 1:17 pm
This forum thread will be used to indicate changes to the Internet Radio station streams - see viewtopic.php?f=42&t=24378
Please report any problems or corrections.
Paul C
Post Wed Mar 14, 2018 1:44 pm
Re: Internet Radio - station changes
1. Station "Bossa Nova Brazil" (in the Latin or previously Brazil category) stream has changed to http://54.38.43.201:8009/stream-128kmp3-BossaNovaBrazil
(corrected in Version 10).
2. Delete Saint FM (St Helena) as it is no longer on Internet Radio only on local FM as a community radio - the link and station are incorrect (it is a different Saint FM).
(removed in version 11).
3. UPDATE BACK ON AIR - Station "Latin - WLJR Latin Jazz Radio (Cuba)" - back on air 15/03/2018.
4. UPDATE - Station "Classic FM (Netherlands)", not to be confused with Classic FM UK, is working but is not available in the UK. Will be in next version.
5. Station "Classical - Venice Classic Radio" stream URL should be changed to http://109.123.116.202:8010/stream1 the old one still works at present.
(Will be changed in version 13).
Paul C
Post Tue Mar 20, 2018 1:12 pm
Re: Internet Radio - station changes and issues
I have been exploring the playlist.groovy plugin to enable input of radio station .m3u and .pls playlists instead of the direct stream URL.
see post viewtopic.php?f=20&t=6022&p=117132#p117132
May include some of these in a future radio station file.
Paul C
Post Sat Mar 24, 2018 3:18 pm
Testing has indicated that a number of stations that were thought to be restricted to the UK are available worldwide.
The descriptions have been amended accordingly in the last version available at viewtopic.php?f=42&t=24378&p=116776#p116776
Paul C
Post Fri May 11, 2018 4:57 pm
6. Station "Asian - AsianFX" (in the Asian genre) appears not to be working or is off-air will check-out. NOW WORKING AGAIN.
7. Venice Classic Radio has moved to an https... playlist address. This affects the playlist tests only. see viewtopic.php?f=20&t=6022&p=117132#p117676
Paul C
Post Sun May 20, 2018 1:59 pm
Re: Internet Radio - The Classic Rock Channel
8. DELETED - "Rock - The Classic Rock Channel" (http://www.theclassicrockchannel.com/) (http://5.135.154.69:12688) has sadly been off-air since 1st May 2018. It is still off-air as of 22/11/2018. They have not replied to my emails so has been removed in download file 19.
Paul C
Post Fri Aug 03, 2018 9:01 pm
Re: Internet Radio - ANY MORE STATIONS
Do any Serviio forum members have more Internet Radio stations to add ?
Paul C
Post Sat Aug 18, 2018 9:14 pm
Re: Internet Radio - Calm Radio Bossa Nova (Canada)
9. Latin(Brazil) - Calm Radio Bossa Nova (Canada) now appears to be available on http://148.72.152.10:10028/stream
It will be amended on the next download.
Paul C
Post Thu Nov 22, 2018 1:03 pm
Re: Internet Radio - Jazz Connection on Radio 257
10. "Jazz - Jazz Connection on Radio 257" appears to be off-air or stopped broadcasting. Removed from download.
Download 19 has been posted - see viewtopic.php?f=42&t=24378&p=116776#p116776
Paul C
Post Thu Nov 22, 2018 2:05 pm
Re: Internet Radio - RelaxingJazz Smooth Jazz from St.
11. Station "Jazz - RelaxingJazz - Smooth Jazz from St. Lucia" has changed to
http://stream-02-eu.relaxingjazz.com/stream/1/
Corrected in Download 19.
Paul C
Post Sat Aug 17, 2019 11:40 am
IN FUTURE I WILL POST CHANGES TO THE MAIN STREAM at viewtopic.php?f=42&t=24378&start=20
PLEASE POST ANY ISSUES THERE AND TREAT THIS STREAM AS CLOSED.
Post Sat Aug 17, 2019 5:47 pm
Thread now locked. Please use the other noted thread.
Return to Audio streams
