H264 level of the file is not a valid number
escapix
Post Sun Mar 27, 2011 4:32 pm
Hi serviio fans,
I am using serviio since 0.4.x version for quite a while now...
From a friend I got an HD AVI video, which I cannot watch on my TV
The file has following details:
C:\Programme\Serviio\lib>ffmpeg.exe -i "z:\video\StiegLarson\Stieg_Larsson__Verb
lendung_Millennium_HD_Teil1.avi"
686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
[avi @ 015ece90] max_analyze_duration reached
Input #0, avi, from 'z:\video\StiegLarson\Stieg_Larsson__Verblendung_Millennium_
HD_Teil1.avi':
Duration: 01:27:10.66, start: 0.000000, bitrate: 2204 kb/s
Stream #0.0: Video: h264, yuv420p, 1280x720 [PAR 1:1 DAR 16:9], 50 fps, 50 t
br, 50 tbn, 100 tbc
Stream #0.1: Audio: mp3, 48000 Hz, 2 channels, s16, 192 kb/s
Tryingg to play back the file results in "Serververbindung nicht möglich...."
serviio.log shows up:
2011-03-27 18:10:36,984 WARN  [VideoTranscodingMatch] H264 level of the file is not a valid number: 3,2
2011-03-27 18:10:38,515 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: FFmpeg execution failed
   at org.serviio.delivery.resource.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:116)
   at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:89)
   at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:116)
   at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:130)
   at org.serviio.upnp.webserver.AbstractRequestHandler.handle(AbstractRequestHandler.java:58)
2011-03-27 18:10:43,609 DEBUG [WebServer] Incoming connection from /192.168.178.26:38022
Full log is attached.
Here is teh DeviceSpy output of my TV:
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG;DLNA.ORG_FLAGS=8cf00000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED;DLNA.ORG_FLAGS=8cf00000000000000000000000000000,
http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM;DLNA.ORG_FLAGS=8cf00000000000000000000000000000,
http-get:*:audio/L16:DLNA.ORG_PN=LPCM;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3_T;SONY.COM_PN=AVC_TS_HD_60_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_50_AC3_T;SONY.COM_PN=AVC_TS_HD_50_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_60_AC3;SONY.COM_PN=AVC_TS_HD_60_AC3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_50_AC3;SONY.COM_PN=AVC_TS_HD_50_AC3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_60_AC3_ISO;SONY.COM_PN=AVC_TS_HD_60_AC3_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_50_AC3_ISO;SONY.COM_PN=AVC_TS_HD_50_AC3_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_EU_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_EU;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_EU_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_KO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_KO_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_JP_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_NA_MPEG1_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_60_L2_T;SONY.COM_PN=HD2_60_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_HD_50_L2_T;SONY.COM_PN=HD2_50_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_NA_MPEG1_L2_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_60_L2_ISO;SONY.COM_PN=HD2_60_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_HD_50_L2_ISO;SONY.COM_PN=HD2_50_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_60_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_50_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_JP_MPEG1_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_MPEG1_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_60_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_50_L2_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_MPEG1_L2_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_24_AC3_T;SONY.COM_PN=AVC_TS_HD_24_AC3_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_24_AC3;SONY.COM_PN=AVC_TS_HD_24_AC3;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_24_AC3_ISO;SONY.COM_PN=AVC_TS_HD_24_AC3_ISO;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_JP_AAC_T;DLNA.ORG_FLAGS=8d700000000000000000000000000000,
http-get:*:video/x-mp2t-mphl-188:*
Question:
What is your advice to configure my profile.xml, to fix WARN messages and finaly can play back the HD AVI video?
Thanks in advance
Eckehard
pc5dczc_HD_AVI.zip
(49.41 KiB) Downloaded 691 times
Post Sun Mar 27, 2011 4:38 pm
Re: H264 level of the file is not a valid number
Try executing this command and post the (error) message:
ffmpeg.exe -i \\192.168.178.24\data\video\StiegLarson\Stieg_Larsson__Verblendung_Millennium_HD_Teil1.avi -y -vcodec copy -vbsf h264_mp4toannexb -copyts -acodec ac3 -ab 384k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts C:\WINDOWS\TEMP\Serviio\transcoding-temp-604-MPEG2TS.stf
escapix
Post Sun Mar 27, 2011 6:38 pm
Hi Petr,
here it is:
C:\Programme\Serviio\lib>ffmpeg.exe -i \\192.168.178.24\data\video\StiegLarson\S
686-mingw32-
[avi @ 015ecfd0] max_analyze_duration reached
Input #0, avi, from '\\192.168.178.24\data\video\StiegLarson\Stieg_Larsson__Verb
lendung_Millennium_HD_Teil1.avi':
br, 50 tbn, 100 tbc
[ac3 @ 0174e010] No channel layout specified. The encoder will guess the layout,
but it might be incorrect.
[mpegts @ 01e30050] muxrate VBR, pcr every 5 pkts, sdt every 200, pat/pmt every
40 pkts
Output #0, mpegts, to 'C:\WINDOWS\TEMP\Serviio\transcoding-temp-604-MPEG2TS.stf'
encoder : Lavf52.92.0
Stream #0.0: Video: H264 / 0x34363248, yuv420p, 1280x720 [PAR 1:1 DAR 16:9],
q=2-31, 90k tbn, 50 tbc
Stream #0.1: Audio: ac3, 48000 Hz, stereo, flt, 384 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Press [q] to stop encoding
h264_mp4toannexb failed for stream 0, codec copy: Invalid data found when proces
sing input
[mpegts @ 01e30050] first pts value must set
av_interleaved_write_frame(): Operation not permitted
Regardless the error message, stf file "C:\WINDOWS\TEMP\Serviio\transcoding-temp-604-MPEG2TS.stf" is attached.
Thanks a lot for your effort!
Regards
Eckehard
transcoding-temp-604-MPEG2TS.zip
(1.43 KiB) Downloaded 690 times
Post Sun Mar 27, 2011 6:57 pm
FFmpeg doesn't like this file for some reason and cannot transcode it, so you're out of luck.
h264_mp4toannexb failed for stream 0, codec copy: Invalid data found when processing input
escapix
Post Sun Mar 27, 2011 7:21 pm
Hi Petr,
thanks again for your support..... looks like online chat here... :D
I will ask my friend about the source he got the video file....
May be, ffmpeg team can help.
cu later
Eckehard
patters
Post Mon Mar 28, 2011 1:20 am
h264 shouldn't really be put into an avi container, which is why I never added a transcode match for this in the Sony BDP profile for instance. See here:
http://en.wikipedia.org/wiki/Comparison ... er_formats
People generally did this before matroska had become popular, when only QuickTime seemed to be able to play mp4 containers so people didn't like to use them either. Most of the time the avi files are damaged in some way, and are often a result of the file's author not really understanding what they're doing. All the ones I have downloaded are unsalvageable - FFmpeg can't remux them.
