LG B7V Profile
Katakana
Post Thu Mar 22, 2018 9:17 am
LG B7V Profile
Hi everybody,
I just bought an LG B7V (OLED UHD, 55 inch). Does anybody have a more specific/customized profile than the default "LG TV/player" for this TV?
I just saw that some files that I was able to playback correctly with my old Samsung H6200 can no longer be played back now, and before going in debugging mode I thought asking first :)
Thanks!
Katakana
Post Sun Apr 01, 2018 7:01 pm
Re: LG B7V Profile
As no replies were received I went on to a small self discovery.
I tried to create a profile for the B7V, based on the info from Intel UPNP Spy. No luck using the Upnp search method. It seemed there was no reply after such a search message.
I tried the HTTP Headers based on what I saw in Serviio's logs, but I was also there out of luck. It seemed the profile was applied, but then another profile was applied...it was pretty strange looking in the logs.
So then I just applied the Samsung H Series profile and at the moment it seems to work ok.
Return to LG
