TX-40DXX689 & TX-32ESW404: Profiles ?
Jean la Bete
Post Thu Mar 22, 2018 11:09 am
Both Panasonic VieraTVs seesm t work with the actual Serviio Server but i dont understand the concept of "profil". Is there a need for set/change the profile for the two devices fpr better results?
Greetings
J.l.B.
Post Thu Mar 22, 2018 12:38 pm
Re: TX-40DXX689 & TX-32ESW404: Profiles ?
Welcome! Profiles are developed to allow players to work their best regardless of the media you are playing. Some brands have more profiles than others because a) the abilities of the devices are noticeably different between models and b) there are users that help develop these new profiles. It's impossible for the Serviio developer to create all of the profiles himself, since you need a player to test with and that would cost a lot of money.
For an example, the developer created a single Roku profile, based on an older Roku player. The newer players introduced many new features, such as 4K and HDR support and faster processors, and the original profile was transcoding many videos that it didn't need to. So users such as myself assisted with creating additional profiles to allow the newer Roku players to play with they support without transcoding.
However, Serviio might not always detect your player correctly (usually not Serviio's fault), so in that case you need to change the assigned profile for your player. It's entirely possible your players are more capable than the profile you are using, and you can experiment with different profiles to see if something else works better. With Serviio, you have complete control of what profile is used by your player. :D
Post Thu Mar 22, 2018 9:43 pm
This is something I did ages ago that may help pick the right profile: viewtopic.php?f=13&t=12367&start=80#p86472
I also have a Panasonic 2015 profile I use for my CS610. Ill post it when I get home.
Post Fri Mar 23, 2018 11:37 am
Attached is my Panasonic 2015 profile - see if that helps.
Save the file to your Serviio\config folder and restart your PC. Then select the profile in Serviio Console against your TV.
user-profiles.xml
(2.91 KiB) Downloaded 2139 times
Return to Panasonic
