Not seeing DNG RAW files
shai
Post Sat Mar 24, 2018 7:16 am
I'm planing on using Serviio to share our family photos with my wife's phone and other devices at home.
I'm running Serviio PRO v1.9.1 (14 days trial) on Windows 10 Pro.
I added a single folder from my Pictures directory on my HDD. It's the '2018' folder that has all of 2018's photos. Those are all sorted in folders as we like to sort them out.
Since I'm a photographer using Nikon, I have DNG RAW files.
The only pictures Serviio shows me are the JPEG files I've got in some sub-folders of those images I've edited and exported.
Does Serviio serve DNG RAW files? Also, should I be seeing thumbnails on the folders? I only see thumbnails when I drill down and reach those folders that contain the exported JPEGs.
If there is anything I need to provide, do let me know. I'm unsure if you need the logs at this point in time.
Post Tue Mar 27, 2018 9:37 am
Re: Not seeing DNG RAW files
yes please, enable detailed log, restart the service and try to add a new raw image
Users browsing this forum: No registered users and 66 guests
