Support for LG twin hd tuner network recorder
kato99
Post Sun Mar 27, 2011 9:26 pm
First of all Awesome Application! but would it be possible to have support for the above mentioned DLNA product ? Rewind and resume(after stopping a movie) would be nice features as well if that is possible? the device is in the link below.Thank You for such an awesome app.
p.s. even with the default profile it play's everything crystal clear (i have tried a lot of dlna server's and nothing comes close to this one :) )
http://www.lg.com/au/tv-audio-video/vid ... MS408D.jsp
Post Sun Mar 27, 2011 11:31 pm
Re: Support for LG twin hd tuner network recorder
You can try using the LG profile that is already there. FFWD/REW should work if the player supports it .. maybe only for certain files. Resume - I'm not sure, so far only the SAmsung C series have this (custom) functionality.
kato99
Post Mon Mar 28, 2011 8:56 am
Hmm kk i have used another DLNA server .. and was able to stop and then when i played again the Machine prompted to resume and it did. (that server pic Quality was crap) ill try the Lg profile see how that works out. thx and keep up the Great work! IMO your Server is by far the best out there.
Return to Feature requests
