No sound
joslinm
Post Mon Apr 16, 2018 11:45 am
No sound
the last several months have been having problems with no sound on some downloaded torrents. They play fine on the computer, but when using Serviio to the tv, I have no sound.
The programs that often don't have sound are higher quality 720P. Lower quality (smaller size) downloads work fine.
Using Windows 10 Serviio to Sony DVD with DNLA to Vizio tv
Any ideas?
Post Mon Apr 16, 2018 12:28 pm
Re: No sound
Need to know what codecs are in the file. Most TVs will only support ac3 audio, so if your file has something else you won't get audio without transcoding. What profile is assigned to your TV?
joslinm
Post Mon Apr 16, 2018 1:09 pm
Re: No sound
atc98092 wrote:Need to know what codecs are in the file. Most TVs will only support ac3 audio, so if your file has something else you won't get audio without transcoding. What profile is assigned to your TV?
How do I find profile?
Same problem whether playing sound through tv or soundbar
Post Mon Apr 16, 2018 4:58 pm
Re: No sound
Look at the Serviio console on the Status tab to see what profile is assigned to your TV. If the soundbar is connected to the TV via optical, then it only gets the sound the TV does. So if it can't process the audio from your file then there's nothing to send to the soundbar. Some TVs don't get the correct profile assigned. If yours is set to the Generic profile, then nothing is transcoded and any audio other than ac3 may not work.
See the link in my signature line to determine the audio codec contained in your media file.
joslinm
Post Fri Apr 27, 2018 11:41 pm
Re: No sound
All the profiles are fine. Tried others too with no success. Then I tried on another computer with an older version of Serviio. Version 1.4.1.2
Played fine.
I'd like to get the new version working though
Post Sat Apr 28, 2018 12:58 am
Re: No sound
Still need to know what profile you are using, and the media information of a file that doesn't play audio. We're all just making guesses without that information.
joslinm
Post Sat Apr 28, 2018 1:53 am
Re: No sound
My sony DVD works as the DLNA device and then from there a cable to the tv and optical to surround receiver
The profile for the DVD is Sony BDP-Sx70/SMP-N100 (2010) on both computers. The older version has sound and newer not
Post Sat Apr 28, 2018 4:57 pm
Re: No sound
What model of Sony BD player do you have? The profile you mentioned is really for older devices. I have a Sony BDP-S3500, and I use the Sony BDP-Sx100 (2013) profile. My connection to the AVR is via HDMI, so I'm unsure if your optical connection is any different. The Sony profiles really haven't been updated since those 2013 models, but I honestly don't know if there's been a need.
What brand/model of AVR are you using? I'm just wondering what audio codecs might be supported.
joslinm
Post Sat Apr 28, 2018 6:15 pm
Re: No sound
I have a BDP-S3200 BluRay. The BDP-Sx70/SMP-N100 (2010) profile worked fine with version 1.4.1.2, but some files have so sound using version 1.9
My connection is also HDMI to the tv
Post Sat Apr 28, 2018 8:27 pm
Re: No sound
joslinm wrote:I have a BDP-S3200 BluRay. The BDP-Sx70/SMP-N100 (2010) profile worked fine with version 1.4.1.2, but some files have so sound using version 1.9
OK, the profile you are using is transcoding in places that you don't need. The profile I use should be a closer match to your player, although as I mentioned it's rather old itself (2013). I also still have a BDP-S3100, which is almost identical to your player. I haven't used it in a while, so I just powered it up and connected to my Serviio box. I've tried several videos with no issue. I am playing them on a 4K Sharp Roku TV. I've tried videos with DTS Master Audio and DD (both 5.1 and 2.0 tracks). I get audio with them all.
I really need the media info for one or more of your files that won't play audio. I need to know what audio codecs they contain, and compare them to the profile you are using.
EDIT: I checked my BDP-S3100 audio out settings, and I do have it set to Stereo downmix. Since I'm connected directly to a TV that doesn't support non-AC3 audio, that makes sense. But I wanted to let you know that I have that setting. Since you are connected directly to a TV, you should probably use the same setting.
joslinm
Post Sat Apr 28, 2018 9:49 pm
Re: No sound
Appreciate your help. I'll work on this
joslinm
Post Sat May 05, 2018 2:40 am
Re: No sound
hope this info is what you need. This file plays fine on computer, but will not play on tv
Unique ID : 113368697500897356511437746421349544816 (0x554A0455593B2C4FA79BE2A04258F370)
Complete name : C:\Users\M\Desktop\Media\The.Cruise.S05E02.720p.AMZN.WEB-DL.DDP2.0.H.264-NTb[eztv].mkv
Format : Matroska
File size : 714 MiB
Duration : 22 min 27 s
Overall bit rate : 4 447 kb/s
Encoded date : UTC 2018-04-13 15:10:12
Writing application : mkvmerge v21.0.0 ('Tardigrades Will Inherit The Earth') 64-bit
Writing library : libebml v1.3.5 + libmatroska v1.4.8
Format : AVC
Format profile : High@L3.1
Format settings : CABAC / 5 Ref Frames
Format settings, CABAC : Yes
Codec ID : V_MPEG4/ISO/AVC
Bit rate mode : Variable
Bit rate : 4 221 kb/s
Maximum bit rate : 4 500 kb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.183
Stream size : 678 MiB (95%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Matrix coefficients : BT.709
Format : E-AC-3
Format/Info : Enhanced Audio Coding 3
Codec ID : A_EAC3
Duration : 22 min 26 s
Bit rate mode : Constant
Bit rate : 224 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Frame rate : 187.500 FPS (256 SPF)
Compression mode : Lossy
Stream size : 36.0 MiB (5%)
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
Post Sat May 05, 2018 7:01 am
Re: No sound
Yes, that is what was needed. Your audio is Dolby Digital Plus (DD+), not standard DD. Most likely your TV doesn't support that audio, which is why you hear nothing. My guess is the Sony profile you are using doesn't pick that up, so it's not being transcoded. I'll have to look at the profile later and see where would the best place be to add a line. It's Midnight and I've been awake for 21 hours, the last 5 babysitting my grandkids. I'm kinda tired. :P
joslinm
Post Mon May 07, 2018 3:25 pm
Re: No sound
atc98092 wrote:Yes, that is what was needed. Your audio is Dolby Digital Plus (DD+), not standard DD. Most likely your TV doesn't support that audio, which is why you hear nothing. My guess is the Sony profile you are using doesn't pick that up, so it's not being transcoded. I'll have to look at the profile later and see where would the best place be to add a line. It's Midnight and I've been awake for 21 hours, the last 5 babysitting my grandkids. I'm kinda tired. :P
hope you didn't forget me sir
Post Mon May 07, 2018 4:47 pm
Re: No sound
Yep, I did... :oops:
I'm not an expert on the Sony profiles, but I'll see if I can figure it out.
joslinm
Post Mon May 07, 2018 5:11 pm
Re: No sound
atc98092 wrote:Yep, I did... :oops:
I'm using a different setup right now. No Soundbar or surround amp attached now
DNLA goes through the same Sony Bluray BDP-S3200 from computer. From there to the TV (Vizio E550i-B2) by HDMI cable. When first trying to play the video, the TV screen says "audio format not supported", then the video plays with no sound.
The TV specs say
DTS StudioSoundtm:
DTS TruSurroundtm:
DTS TruVolumetm:
Here's something else to think about. I burned the file to a dvd and the video plays fine with sound through the Bluray
Post Tue May 08, 2018 12:29 am
Re: No sound
The TV specs say
DTS StudioSoundtm:
DTS TruSurroundtm:
DTS TruVolumetm:
Sometimes BD players may decode audio to what it believes is supported. All BD players have Dolby Digital decoders, so is probably taking the DD+ down to DD. It just isn't doing it with DLNA material. Just because it will work from a disc doesn't mean it will do the same with DLNA material, unfortunately. :x
So, looking at the Sony profile you mentioned (BDP-Sx70/SMP-N100 (2010)), I have a best guess on where to add a transcoding line. At line 1500 in the profiles.xml file is this:
<Video targetContainer="mpegts" targetACodec="ac3" aBitrate="320" forceInheritance="true">
      <Matches container="matroska" aCodec="dts-hd" />
      <Matches container="matroska" aCodec="vorbis" />
      <Matches container="matroska" aCodec="truehd" />
            <Matches container="matroska" aCodec="flac" />
           <Matches container="mpeg" aCodec="lpcm" />
      <Matches container="ogg" vCodec="mpeg4" />
      <Matches container="mp4" aCodec="lpcm" />
Add this line in the Matches section:
<Matches container="*" aCodec="eac3" />
Save the file and restart the Serviio process. The easiest way is to reboot the computer. Then try playing a file that didn't have sound before. This section of transcoding leaves the video alone, but will match any file that contains Dolby Digital +, regardless of container. Since you are playing the video with no problem, its best to try adding it here first.
joslinm
Post Tue May 08, 2018 2:43 am
Re: No sound
I am able to find C:\Program Files\Serviio\config\profiles.xml and then lost. I can click view source, but can't find a way to edit anything
joslinm
Post Tue May 08, 2018 11:54 am
Re: No sound
The TV specs say
DTS StudioSoundtm:
DTS TruSurroundtm:
DTS TruVolumetm:
Post Tue May 08, 2018 1:12 pm
Re: No sound
joslinm wrote:I am able to find C:\Program Files\Serviio\config\profiles.xml and then lost. I can click view source, but can't find a way to edit anything
The XML format is just text, so you can use Windows Notepad. However, you'll find it much easier to work with if you install Notepad ++. It's free and provides color coding to the text to help understand it all. Then just copy and paste the line I provided where I mentioned.
Return to General discussion
