serviigo & mediabrowser to chromecast, file won't play
freaknik
Post Thu Apr 26, 2018 3:02 am
Complete name               : E:\movies\over.the.top-vRs.avi
Format                      : AVI
Format/Info                 : Audio Video Interleave
File size                   : 699 MiB
Duration                    : 1h 33mn
Overall bit rate            : 1 045 Kbps
Writing application         : VirtualDubMod 1.5.4.1 (build 2178/release)
Writing library             : VirtualDubMod build 2178/release
Format                      : MPEG-4 Visual
Format profile              : Advanced Simple@L5
Format settings, BVOP       : 1
Format settings, QPel       : No
Format settings, GMC        : No warppoints
Format settings, Matrix     : Default (H.263)
Muxing mode                 : Packed bitstream
Codec ID                    : XVID
Codec ID/Hint               : XviD
Duration                    : 1h 33mn
Bit rate                    : 846 Kbps
Width                       : 640 pixels
Height                      : 272 pixels
Display aspect ratio        : 2.35:1
Frame rate                  : 23.976 fps
Color space                 : YUV
Chroma subsampling          : 4:2:0
Bit depth                   : 8 bits
Scan type                   : Progressive
Compression mode            : Lossy
Bits/(Pixel*Frame)          : 0.203
Stream size                 : 566 MiB (81%)
Writing library             : XviD 1.2.0.dev47 (UTC 2006-11-01)
Format                      : AC-3
Format/Info                 : Audio Coding 3
Format profile              : Dolby Digital
Mode extension              : CM (complete main)
Codec ID                    : 2000
Duration                    : 1h 33mn
Bit rate mode               : Constant
Bit rate                    : 192 Kbps
Channel(s)                  : 2 channels
Channel positions           : Front: L R
Sampling rate               : 48.0 KHz
Delay relative to video     : 7ms
Stream size                 : 129 MiB (18%)
Alignment                   : Split accross interleaves
Interleave, duration        : 83 ms (2.00 video frames)
Interleave, preload duratio : 500 ms
Language                    : English
This video plays fine on mediabrowser on my phone and through mediahouse to my bluray but won't cast and serviigo to localcast gives me the poop of doom. It's a sad poop face that says no codec support. How can I get it to play on chromecast?
Thanks guys, great work on the board as always and appreciate serviio big time.
ps. On my network the chromecast is 192.168.0.102 and the bluray is 192.168.0.111 and 192.168.0.103 is my phone.
(492.67 KiB) Downloaded 600 times
Post Thu Apr 26, 2018 12:33 pm
Re: serviigo & mediabrowser to chromecast, file won't play
are you using Chromecast from MediaBrowser? logs look ok.
freaknik
Post Mon Apr 30, 2018 2:58 pm
yes I tried that and Serviigo -> localcast -> chromecast and nothing plays, just goes the the chromecast symbol and black background.
I tried on a laptop with vlc and it plays the video but no sound.
thanks for responding, sorry it took me a while to get back.
Users browsing this forum: No registered users and 74 guests
