HOWTO: set proper Java in Ubuntu Bionic 18.04 LTS
skiaccianos
Post Fri Apr 27, 2018 8:14 am
Hi all,
Ubuntu Bionic has been released yesterday and ships a new default java (openjdk-11-jre/bionic,now 10.0.1+10-3ubuntu1): Serviio is not working with this release, so you have to install jre 8 alongside the 11 and make it the default. Like this:
matteo@TMP258-MG:~$ sudo apt list --installed |grep jre
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
default-jre/bionic,now 2:1.10-63ubuntu1~02 amd64 [installato, automatico]
default-jre-headless/bionic,now 2:1.10-63ubuntu1~02 amd64 [installato, automatico]
openjdk-11-jre/bionic,now 10.0.1+10-3ubuntu1 amd64 [installato, automatico]
openjdk-11-jre-headless/bionic,now 10.0.1+10-3ubuntu1 amd64 [installato, automatico]
openjdk-8-jre/bionic,now 8u162-b12-1 amd64 [installato]                                              <<<<< apt get install this one
openjdk-8-jre-headless/bionic,now 8u162-b12-1 amd64 [installato, automatico]
matteo@TMP258-MG:~$ sudo update-alternatives --config java
Sono disponibili 2 scelte per l'alternativa java (che fornisce /usr/bin/java).
  Selezione    Percorso                                        Priorità  Stato
  0            /usr/lib/jvm/java-11-openjdk-amd64/bin/java      1101      modalità automatica
  1            /usr/lib/jvm/java-11-openjdk-amd64/bin/java      1101      modalità manuale
* 2            /usr/lib/jvm/java-8-openjdk-amd64/jre/bin/java   1081      modalità manuale
Press <enter> to keep the current choice[*], or type selection number: 2
matteo@TMP258-MG:~$
Regards
Running Serviio - for several years now - on Debian and Win boxes.
R850R biker, sysadmin & DBA, FOSS and Linux enthusiast (desktop_is_home_dir)
Post Fri Apr 27, 2018 8:53 am
Re: HOWTO: set proper Java in Ubuntu Bionic 18.04 LTS
how does it fail with Java 11?
There is support for Java 9 in serviio.sh
# Check if we are using Java9
JAVA_VERSION=$("$JAVA" -version 2>&1 | awk -F '"' '/version/ {print $2}')
case "$JAVA_VERSION" in
    \9*) JAVA9_OPTS="--add-modules java.xml.ws,jdk.unsupported" ;;
    *) JAVA9_OPTS="" ;;
esac
I assume it'd have to be updated for Java 10/11 and use the same behaviour as for Java 9 (ie add the --add-module opts)
skiaccianos
Post Fri Apr 27, 2018 10:14 pm
Hi zip,
this is how it fails
Press <enter> to keep the current choice[*], or type selection number: 0
update-alternatives: viene usato /usr/lib/jvm/java-11-openjdk-amd64/bin/java per fornire /usr/bin/java (java) in modalità automatica
matteo@TMP258-MG:~$
matteo@TMP258-MG:~$
matteo@TMP258-MG:~$ iio
[1] 9097
matteo@TMP258-MG:~$
matteo@TMP258-MG:~$
matteo@TMP258-MG:~$
matteo@TMP258-MG:~$
[1]+  Completato              /home/matteo/.serviio/bin/serviio.sh
matteo@TMP258-MG:~$
matteo@TMP258-MG:~$
bolzass
Post Sat Apr 28, 2018 8:08 am
Re: HOWTO: set proper Java in Ubuntu Bionic 18.04 LTS (updat
Hi skiaccianos!,
Nothing to see here....
But to fix what zip is talking about, you should add versions to case... Several ways:
Add lines with versions, or just merge it in the case:
# Check if we are using Java9, or 10...
    9*|10*) JAVA9_OPTS="--add-modules java.xml.ws,jdk.unsupported" ;;
    *) JAVA9_OPTS="" ;;
esac
Or change the case with only to check if greater or equal than 9:
# Check if we are using Java9 or greater...
JAVA_VERSION=$("$JAVA" -version 2>&1 | sed -n ';s/.* version "\(.*\)\.\(.*\)\..*".*/\1\2/p;')
[ "$JAVA_VERSION" -gt 18 ] && JAVA9_OPTS="--add-modules java.xml.ws,jdk.unsupported" || JAVA9_OPTS=""
I changed it for you by the 2nd options in serviio.sh
[EDITED]. Corrected case words and updated serviio.sh (Thanks zip)
serviio.sh.zip
(1.1 KiB) Downloaded 661 times
Post Sat Apr 28, 2018 12:31 pm
[quote="bolzass"
But to fix what zip is talking about, you should add versions to case... [/quote]
Are you sure your case works?
Java 8's -version results in something like 1.8.0-xxx
Java 9's -version results in something like 9 (not 1.9)
But maybe I'm just not reading the sed line correctly
bolzass
Post Sat Apr 28, 2018 1:59 pm
zip wrote:Are you sure your case works?
You are right!, didn't noticed about it :oops:. It should be:
    *) JAVA9_OPTS="" ;;
esac
zip wrote:But maybe I'm just not reading the sed line correctly
You read it fine, in that case would work also as would result in 9x and 10x (90 & 100 for the last ones) for versions >=9, that are greater than 18 and would take into account new java numbering in the future updates (18.9, etc.) :mrgreen: [this is which I prefer]. Ops :oops: , also mistaken (put 19 not 18..):
Will correct original post!!!!. Thanks zip!
Users browsing this forum: No registered users and 123 guests
