multiple genres
greekdroid
Post Tue Apr 17, 2018 1:23 pm
multiple genres
Hy
Is there a way to add the same title to multiple genres?
Many thanks
Post Wed Apr 18, 2018 1:22 pm
Re: multiple genres
sure, depends on the metadata source, but they all support multiple genres (online, XBMC, etc)
greekdroid
Post Mon Apr 30, 2018 2:47 pm
Re: multiple genres
How I have to do it so that track is put into different genres? At the moment I use the syntax "Funk\\Jazz" and Serviio makes a new genre out of it. But I want the track to be shown me in the two genres funk and jazz.
Best Regards
Post Mon Apr 30, 2018 9:58 pm
Re: multiple genres
Ah, I was talking about video. Can audio even be in multiple genres via id3 tags?
greekdroid
Post Tue May 01, 2018 8:10 am
Re: multiple genres
yes, with \\ you can insert multiple genres.
Post Tue May 01, 2018 9:14 am
Re: multiple genres
Aparently there is no standard. Here they suggest semicolon: https://www.blisshq.com/music-library-m ... s-in-mp3s/
Here they suggest the same as you: https://community.mp3tag.de/t/multiple- ... ag/17159/3
I'll create a ticket.
greekdroid
Post Thu May 03, 2018 4:30 pm
Re: multiple genres
then I understand correctly that it is not possible at the moment.
Post Thu May 03, 2018 7:40 pm
Re: multiple genres
no
DonaldS
Post Tue Jun 05, 2018 9:56 am
Re: multiple genres
zip wrote:Aparently there is no standard. Here they suggest semicolon: https://www.blisshq.com/music-library-m ... s-in-mp3s/
Thanks for the resource. Guess I've to give it a try.
greekdroid
Post Wed Oct 24, 2018 5:59 am
Re: multiple genres
Hi
In the release 1.10 you added the support for multiple genres in audio files.
Can you tell me which is the character of the separation?
Kind regards
Post Thu Oct 25, 2018 12:11 pm
Re: multiple genres
Try comma or semicolon or forward slash
greekdroid
Post Fri Oct 26, 2018 6:23 am
Re: multiple genres
Very good thank you. But is the character forward slash a good choice? Is this not used for the Gendre "Jazz/Funk" or "Pop/Rock" etc.?
Return to User experiences
