MKV issue on B650
gegMopo3
Post Sat Mar 26, 2011 9:48 am
MKV issue on B650
Hi guys,
I'm running Serviio 0.5.1 with Samsung TV (B-series) profile. TV connected over wired network. Transcoding is enabled. TV says that video not supported. Mediainfo and bitrateviewer logs are attached.
It looks like I need to transcode this video but I dont know that setting should be used.
Complete name : D:\Download\Criminal Minds 6\Criminal.Minds.S06E11.720p.WEB-DL.Rus_Fox.mkv
Format : Matroska
File size : 1.41 GiB
Duration : 42mn 50s
Overall bit rate : 4 714 Kbps
Encoded date : UTC 2011-03-04 10:59:41
Writing application : mkvmerge v4.4.0 ('Die Wiederkehr') сборка от Oct 31 2010 21:52:48
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Format : AVC
Format profile : High@L3.1
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Muxing mode : Container profile=Unknown@3.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 42mn 50s
Bit rate : 4 045 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.183
Stream size : 1.21 GiB (86%)
Title : Criminal Minds - Season 6, Episode 11: 25 to Life
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 42mn 50s
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 58.8 MiB (4%)
Title : FoxCrime
Language : Russian
Audio #2
Format : AC-3
Codec ID : A_AC3
Duration : 42mn 50s
Bit rate : 384 Kbps
Channel(s) : 6 channels
Stream size : 118 MiB (8%)
Title : Dolby Digital 5.1 @ 384 kbps
Post Mon Mar 28, 2011 7:13 am
Re: MKV issue on B650
gegMopo3 wrote:... TV says that video not supported. Mediainfo and bitrateviewer logs are attached.
Thanks for that informations.
gegMopo3 wrote:Writing application : mkvmerge v4.4.0 ('Die Wiederkehr') сборка от Oct 31 2010 21:52:48
H264 profile/level seems compatible, bitrate too. With mkvmerge you could have some problem with "header compression" feature.
Could you provide mkvinfo result of your file?
You could also check that viewtopic.php?f=6&t=1132#p5402 .
gegMopo3
Post Mon Mar 28, 2011 8:32 am
Thank you for the reply. My MKVs have header removal feature enabled. Your solution works fine but audio was still unavailable. I've removed compression for it and now everything OK.
Thanks again :)
Here is the requested log:
+ EBML head
|+ EBML version: 1
|+ EBML read version: 1
|+ EBML maximum ID length: 4
|+ EBML maximum size length: 8
|+ Doc type: matroska
|+ Doc type version: 2
|+ Doc type read version: 2
+ Segment, size 1514585847
|+ Seek head (subentries will be skipped)
|+ EbmlVoid (size: 4044)
|+ Segment information
| + Timecode scale: 1000000
| + Muxing application: libebml v1.0.0 + libmatroska v1.0.0
| + Writing application: mkvmerge v4.4.0 ('Die Wiederkehr') сборка от Oct 31 2010 21:52:48
| + Duration: 2570.176s (00:42:50.176)
| + Date: Fri Mar 04 10:59:41 2011 UTC
| + Segment UID: 0x90 0x68 0xab 0x9d 0xdd 0xd3 0x32 0x89 0x9c 0xea 0x30 0xca 0xf4 0x74 0xcb 0x67
|+ Segment tracks
| + A track
| + Track number: 1
| + Track UID: 1996241570
| + Track type: video
| + Lacing flag: 0
| + MinCache: 1
| + Codec ID: V_MPEG4/ISO/AVC
| + CodecPrivate, length 92 (h.264 profile: High @L3.1)
| + Default duration: 41.708ms (23.976 fps for a video track)
| + Name: Criminal Minds - Season 6, Episode 11: 25 to Life
| + Video track
| + Pixel width: 1280
| + Pixel height: 720
| + Display width: 1280
| + Display height: 720
| + Content encodings
| + Content encoding
| + Content compression
| + Algorithm: 3 (header removal)
| + Settings: length 1, data: 0x00
| + A track
| + Track number: 2
| + Track UID: 2797175690
| + Track type: audio
| + Codec ID: A_AC3
| + Default duration: 32.000ms (31.250 fps for a video track)
| + Language: rus
| + Name: FoxCrime
| + Audio track
| + Sampling frequency: 48000
| + Channels: 2
| + Content encodings
| + Content encoding
| + Settings: length 2, data: 0x0b 0x77
| + A track
| + Track number: 3
| + Track UID: 662726273
| + Track type: audio
| + Default flag: 0
| + Codec ID: A_AC3
| + Name: Dolby Digital 5.1 @ 384 kbps
| + Audio track
| + Channels: 6
| + Content encodings
| + Content encoding
|+ EbmlVoid (size: 1164)
|+ Cluster
aussie2sweden
Post Fri Sep 02, 2011 5:11 pm
it would be great if you could clarify on what you did to fix it...
i am also having .mkv problems on my B.. .funny thing is if i change to A profile they work.. and the other files no longer work.. so i have to switch between profiles.. quite annoying..
Post Fri Sep 02, 2011 5:46 pm
aussie2sweden wrote:it would be great if you could clarify on what you did to fix it...
follow previous poster example and post " details on fiel that will not play " (howto in my signiture)
aussie2sweden
Post Sat Sep 03, 2011 3:04 pm
I have a Samsung B panel..
the first file weeds.s07e03.720p.hdtv.x264-ctu.mkv plays in Samsung B profile fine.. also in A profile
weeds.s07e03.720p.hdtv.x264-immerse.mkv': comes up with 'audio codec not supported' in b profile but works in A profile
(works in A with transcoding turned on, but not in off)
Most more common video files wont work in A profile..
So i am stuck
i have looked thru the reports looking for differences the old small difference is in the second file (immerse version) in the media info report in the audio section the report lists... Title English, Lang English.. otherwise dont see a difference between audio codec..
It is becoming more common to need to switch to A profile for the odd .mkv file..
thanks for your time.. much appreciated.. :-)
getprotocolinfo.txt
get protocol
(16.55 KiB) Downloaded 855 times
media info report.txt
media info
(6.2 KiB) Downloaded 807 times
ffmpeg.txt
ffmpeg report
(3.23 KiB) Downloaded 810 times
Post Sat Sep 03, 2011 4:15 pm
aussie2sweden wrote:I have a Samsung B panel..
So i am stuck
looks like a header compression issue on the second file or maybe a corrupt file as it reports.
[matroska,webm @ 0038bdd0] Unknown entry 0x63C9
aussie2sweden
Post Sat Sep 03, 2011 5:29 pm
ok.. if the file named... weeds.s07e03.proper.720p.hdtv.x264-immerse.mkv why does it play when i change the profile to A.. with transcoding turned on... i often need to change over 720p tv rips to Samsung A Profile to play it.. but change it back to watch everything else..
thanks for taking the time to reply.. i am happy to provide further info as requested..
Post Sun Sep 04, 2011 8:15 pm
profile A transcodes to mpeg2 while profile B probably only remuxes the file, leaving the original stream as is (and the TV not liking the stream for some reason)
