Cannot coonect to server
Post Wed May 09, 2018 6:53 pm
Re: Cannot coonect to server
I have to defer to Zip now. I've exhausted my skill set for evaluating the log. Sorry I can't help more... :(
Post Thu May 10, 2018 8:32 am
There is nothing in the logs showing any problem on the Serviio side.
If you have drop-outs, I'd suggest checking:
- wifi connection is strong, potentially change the channel you use
- check the router for some UPnP settings and aslo read through this: viewtopic.php?f=5&t=10289
Smegsie
Post Thu May 10, 2018 6:13 pm
Never any issue until a few weeks ago
WIFI signal strong and nothing changed
None of the devices will connect, sometimes after re-booting it it come back on briefly for a few minutes.
I don't know enough about my hub to change any UPnP settings, I've had a look and don't don't know what I'm looking at, I only get the option to enable and disable; but again nothing has changed.
Whilst having this problem I have installed Plex, granted this isn't as good as serviio but does work and connects.
the_hamburger
Post Sat May 12, 2018 6:26 am
Since eagerly awaited update to 1.92 I'm also getting "Cannot connect to server"
OSX 10.13.4
the_hamburger
Post Sun May 13, 2018 10:35 am
After a day and several reboots I'm happy to report that its all cleared up.
No idea why.
Smegsie
Post Sun May 13, 2018 9:09 pm
I still have the same issue, anything else?
Previous
Users browsing this forum: No registered users and 51 guests
