The best version
• Page 1 of 1
The only version that works without problem in advancing the movie is version 1.7.1 because the other versions like 1.8 and 1.9 appears the invalid file error when the movie advances on TV. the only problem that in version 1.7.1 does not appear on my computer in windows 10. because I tested all versions of the service, because the best and 1.7.1
Re: The best version
Need more information. What make/model of TV? What are your media formats (container, audio and video codecs used)? What profile is assigned to your TV?
same movie in mkv, when it advances the film in versions 1.8 or 1.9 of this error in any tv, I tested in LG, sansung among others.
In version 1.7 works perfect, being able to advance the film perfectly without problem.
follow the video on youtube that made the demonstration
https://youtu.be/GOhTSAGSSRA
rodrigoitaqui wrote:http://forum.serviio.org/viewtopic.php?f=6&t=24554
the same problem
The post you just listed is not the same issue.
When you say advances, do you mean you can't fast forward? Do you get the invalid file error with all media, or only specific videos? Again, we need more detailed information about your TV and your media. See the questions I asked earlier.
I believe that English isn't your primary language, but I'm having difficulty following exactly what your problem is. You might make a post in your native language, and hopefully someone here can translate more clearly or offer some help.
atc98092 wrote:rodrigoitaqui wrote:http://forum.serviio.org/viewtopic.php?f=6&t=24554
the same problem
When you say advances, do you mean you can't fast forward? yes, when the movie advances in mkv extension
Do you get the invalid file error with all media, or only specific videos? I took the tests on mkv
download hd or full hd movie in mkv and make a test, try to advance the movie in versions 1.8 1.9, because it does not work
Again, what do you mean by advance? Are you trying to fast forward the video? Or do you simply mean to begin playback?
What model TV are you using? What Serviio profile is set for the TV? Just saying they are MKV files doesn't tell us anything. MKV is a container and can have a number of different video and audio codecs inside. We need to know what is inside the container.
I watched your video but I could not follow the problem because I do not speak the same language. I am sorry about that.
• Page 1 of 1
Users browsing this forum: Baidu [Spider] and 22 guests
