Still Get Sirviio Notifications on TV
Drumheadnyc
Post Sun May 27, 2018 3:38 pm
I am puzzled. I uninstalled Sirviio ( I do not know what version) from my iMac but my Samsung TV still notifies me (via a popup on the screen while I am watching TV) that my "Sirviio iMac" is available to connect to.
I have done the following:
1. Uninstalled Sirviio by dragging it from applications to the garbage bin.
2. Made sure file sharing is turned off on the iMac.
3. Turned off ALLShare on the Samsung TV.
4. Looked for any sign of Sirviio within the library (did not find anything).
5. I found this suggestion somewhere within this forum which stated to see if there's still some traces of Sirviio left, use this command in terminal "sudo launchctl list | grep serviio", it should not produce a response if Sirviio has been completely removed. When I do it, this is the response it produces "76 0 org.serviio.server"
I do not know what else to do. Can someone please help me make sure it is uninstalled?
Thank you in advance.
Post Thu May 31, 2018 7:40 pm
Re: Still Get Sirviio Notifications on TV
Follow this: http://serviio.org/index.php?option=com ... e&id=21#q4
By moving the app from Applications you only removed the console, not the server
