License not Valid
bigbobber99
Post Sun Jun 03, 2018 2:47 pm
License not Valid
Hey , serviio pro works always fine since i buy it .
But a few days ago , i have this error , "the License is not Valid" i cannot load it.
I have de-install and re-install serviio but same prob . , my system date is 3.6.2018 .
and the log file say this :
2018-06-03 12:00:23,819 WARN [LicenseUploadServerResource] License is not stored because it's not valid: License failed validation these tests: The current date is after the license expiration date
org.serviio.licensing.InvalidLicenseException: License failed validation these tests: The current date is after the license expiration date
at org.serviio.licensing.LicenseValidator.validateLicense(LicenseValidator.java:114)
at org.serviio.licensing.LicenseValidator.validateProvidedLicense(LicenseValidator.java:87)
at org.serviio.licensing.LicensingManager.validateLicense(LicensingManager.java:138)
at org.serviio.ui.resources.server.LicenseUploadServerResource.save(LicenseUploadServerResource.java:35)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at org.restlet.resource.ServerResource.doHandle(ServerResource.java:521)
at org.restlet.resource.ServerResource.put(ServerResource.java:1405)
at org.restlet.resource.ServerResource.doHandle(ServerResource.java:610)
at org.restlet.resource.ServerResource.doNegotiatedHandle(ServerResource.java:679)
at org.restlet.resource.ServerResource.doConditionalHandle(ServerResource.java:357)
at org.serviio.restlet.AbstractServerResource.doConditionalHandle(AbstractServerResource.java:49)
at org.restlet.resource.ServerResource.handle(ServerResource.java:1014)
at org.restlet.resource.Finder.handle(Finder.java:246)
at org.restlet.routing.Filter.doHandle(Filter.java:159)
at org.restlet.routing.Filter.handle(Filter.java:206)
at org.restlet.routing.Router.doHandle(Router.java:431)
at org.restlet.routing.Router.handle(Router.java:648)
at org.restlet.engine.application.StatusFilter.doHandle(StatusFilter.java:155)
at org.restlet.engine.CompositeHelper.handle(CompositeHelper.java:211)
at org.restlet.engine.application.ApplicationHelper.handle(ApplicationHelper.java:84)
at org.restlet.Application.handle(Application.java:384)
at org.restlet.Component.handle(Component.java:406)
at org.restlet.Server.handle(Server.java:516)
at org.restlet.engine.connector.ServerHelper.handle(ServerHelper.java:72)
at org.restlet.engine.adapter.HttpServerHelper.handle(HttpServerHelper.java:152)
at org.restlet.ext.simple.internal.SimpleContainer.handle(SimpleContainer.java:80)
at org.simpleframework.http.core.Dispatcher.dispatch(Dispatcher.java:121)
at org.simpleframework.http.core.Dispatcher.run(Dispatcher.java:103)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Caused by: net.padlocksoftware.padlock.validator.ValidatorException: The license did not pass validation
at net.padlocksoftware.padlock.validator.Validator.validate(Validator.java:349)
at net.padlocksoftware.padlock.validator.Validator.validate(Validator.java:298)
at org.serviio.licensing.LicenseValidator.validateLicense(LicenseValidator.java:105)
... 53 more
2018-06-03 12:00:23,884 WARN [ServiioStatusService] ValidationException occurred. Returning error code 400 to the REST layer. Message: License failed validation these tests: The current date is after the license expiration date
org.serviio.restlet.ValidationException: License failed validation these tests: The current date is after the license expiration date
at org.serviio.ui.resources.server.LicenseUploadServerResource.save(LicenseUploadServerResource.java:42)
i hope you can help !!!!!
i dont know whats wrong .
Post Mon Jun 04, 2018 9:36 am
Re: License not Valid
There was a bug in the license generator for about 3 weeks, starting at the end of April. I have resent the licenses to the affected users. In any case, send email to sales[at]serviio[dot]org and I'll issue you a new one
