Most Files are not shown on my Samsung LE40C650 TV
dag0
Post Fri Mar 25, 2011 1:06 pm
Hello!
I have Serviio running on my Xp-PC and my Video-Files are located on my NAS. Most of them Blue Ray Rips. After having changed the serviio-service-account to "Administrator" I finally can see some of my video-files located on the NAS on my TV. But most of them not!
The files not appearing on my TV do not appear neither in the serviio-log during media-scan.
AVMedia Controller shows only those files for serviio I can also see on my Samsung LE40C650. ffmpeg -i on those files not shown up gives me error-messages like these: (All Blue Ray, first two created whith Handbrake, second whith ribbot264))
D:\Program Files\Serviio\lib>ffmpeg -i "o:\Shared Videos\Benjamin Button.mkv"
686-mingw32-
  libavutil     50.36. 0 / 50.36. 0
  libavcore      0.16. 0 /  0.16. 0
  libavcodec    52.108. 0 / 52.108. 0
  libavformat   52.92. 0 / 52.92. 0
  libavdevice   52. 2. 3 / 52. 2. 3
  libavfilter    1.72. 0 /  1.72. 0
  libswscale     0.12. 0 /  0.12. 0
[matroska,webm @ 015ecd00] max_analyze_duration reached
[matroska,webm @ 015ecd00] Estimating duration from bitrate, this may be inaccur
ate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/
1001) -> 23.98 (48000/2002)
Input #0, matroska,webm, from 'o:\Shared Videos\Benjamin Button.mkv':
  Duration: 02:46:04.19, start: 0.000000, bitrate: 640 kb/s
    Stream #0.0: Video: h264, yuv420p, 1920x1080 [PAR 1:1 DAR 16:9], 23.98 fps,
23.98 tbr, 1k tbn, 47.95 tbc
    Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 640 kb/s
    Stream #0.2(ger): Subtitle: pgssub
D:\Program Files\Serviio\lib>ffmpeg -i "o:\Shared Videos\Inception.mkv"
686-mingw32-
[matroska,webm @ 015ecd10] Estimating duration from bitrate, this may be inaccur
ate
Seems stream 0 codec frame rate differs from container frame rate: 180000.00 (18
0000/1) -> 1000.00 (1000/1)
Input #0, matroska,webm, from 'o:\Shared Videos\Inception.mkv':
  Duration: 02:28:07.92, start: 0.000000, bitrate: 1280 kb/s
    Stream #0.0(eng): Video: h264, yuv420p, 1920x800 [PAR 1:1 DAR 12:5], 23.98 f
ps, 1k tbr, 1k tbn, 180k tbc
    Stream #0.1(deu): Audio: ac3, 48000 Hz, 5.1, s16, 640 kb/s
    Stream #0.2(eng): Audio: ac3, 48000 Hz, 5.1, s16, 640 kb/s
D:\Program Files\Serviio\lib>ffmpeg -i "o:\Shared Videos\Avatar_BR.mkv"
686-mingw32-
[matroska,webm @ 015ecd10] max_analyze_duration reached
ate
Input #0, matroska,webm, from 'o:\Shared Videos\Avatar_BR.mkv':
    title           : Avatar_BD
  Duration: 02:41:41.69, start: 0.000000, bitrate: 1536 kb/s
    Chapter #0.0: start 0.000000, end 377.961000
      title           : 00:00:00.000
    Chapter #0.1: start 377.961000, end 473.598000
      title           : 00:06:17.961
    Chapter #0.2: start 473.598000, end 724.891000
      title           : 00:07:53.598
    Chapter #0.3: start 724.891000, end 840.465000
      title           : 00:12:04.891
    Chapter #0.4: start 840.465000, end 1200.574000
      title           : 00:14:00.465
    Chapter #0.5: start 1200.574000, end 1440.230000
      title           : 00:20:00.574
    Chapter #0.6: start 1440.230000, end 1613.278000
      title           : 00:24:00.230
    Chapter #0.7: start 1613.278000, end 1901.900000
      title           : 00:26:53.278
    Chapter #0.8: start 1901.900000, end 2013.428000
      title           : 00:31:41.900
    Chapter #0.9: start 2013.428000, end 2143.850000
      title           : 00:33:33.428
    Chapter #0.10: start 2143.850000, end 2611.859000
      title           : 00:35:43.850
    Chapter #0.11: start 2611.859000, end 2963.627000
      title           : 00:43:31.859
    Chapter #0.12: start 2963.627000, end 3269.975000
      title           : 00:49:23.627
    Chapter #0.13: start 3269.975000, end 3596.051000
      title           : 00:54:29.975
    Chapter #0.14: start 3596.051000, end 3910.198000
      title           : 00:59:56.051
    Chapter #0.15: start 3910.198000, end 4296.417000
      title           : 01:05:10.198
    Chapter #0.16: start 4296.417000, end 4511.006000
      title           : 01:11:36.417
    Chapter #0.17: start 4511.006000, end 4829.116000
      title           : 01:15:11.006
    Chapter #0.18: start 4829.116000, end 5081.910000
      title           : 01:20:29.116
    Chapter #0.19: start 5081.910000, end 5764.801000
      title           : 01:24:41.910
    Chapter #0.20: start 5764.801000, end 5875.786000
      title           : 01:36:04.801
    Chapter #0.21: start 5875.786000, end 6273.100000
      title           : 01:37:55.786
    Chapter #0.22: start 6273.100000, end 6495.489000
      title           : 01:44:33.100
    Chapter #0.23: start 6495.489000, end 6833.868000
      title           : 01:48:15.489
    Chapter #0.24: start 6833.868000, end 6932.884000
      title           : 01:53:53.868
    Chapter #0.25: start 6932.884000, end 7118.820000
      title           : 01:55:32.884
    Chapter #0.26: start 7118.820000, end 7325.568000
      title           : 01:58:38.820
    Chapter #0.27: start 7325.568000, end 7533.859000
      title           : 02:02:05.568
    Chapter #0.28: start 7533.859000, end 7801.835000
      title           : 02:05:33.859
    Chapter #0.29: start 7801.835000, end 8167.284000
      title           : 02:10:01.835
    Chapter #0.30: start 8167.284000, end 8390.841000
      title           : 02:16:07.284
    Chapter #0.31: start 8390.841000, end 8750.325000
      title           : 02:19:50.841
    Chapter #0.32: start 8750.325000, end 9074.065000
      title           : 02:25:50.325
    Chapter #0.33: start 9074.065000, end 9305.296000
      title           : 02:31:14.065
    Chapter #0.34: start 9305.296000, end 9701.692000
      title           : 02:35:05.296
    Stream #0.1(ger): Audio: dca, 48000 Hz, 5.1, s16, 1536 kb/s
    Stream #0.2: Attachment: mjpeg
      filename        : Poster
Those files play fine whith VLC or with twonky on my NAS. Any help apreciated.
bye,
dag0
Post Fri Mar 25, 2011 1:19 pm
Re: Most Files are not shown on my Samsung LE40C650 TV
The ffmpeg outputs are ok. It might take some time to add all the files. Keep checking the log. Otherwise enable debug logging, click Force refresh and send the log.
dag0
Post Fri Mar 25, 2011 2:46 pm
OK, thanks - you're right. Obviously I was to impatient! :) I didn't expect the media-scan last that long.
Other thing is, during playback of a mkv from my NAS on my TV my PC crashed. No message according to this in my event-log. I hope this was a unique event! :o
And: Playback is oftem stuttering. Some files less, some more. Normally this shouldn't happen? Works flawless when playing directly from the DLNA-Server on my NAS. PC, NAS and TV are all cabled to my router.
Post Fri Mar 25, 2011 2:52 pm
Stuttering: I don't experience any but obviously you have 1 more hop in your route.
NAS -> TV
vs
NAS -> PC (Serviio) -> TV
It still should work ok as you're on wired network.
dag0
Post Fri Mar 25, 2011 3:24 pm
Yes - this was also my thought. Don't know why this doesn't work, normaly those 2 hops should't be a problem! :(
dag0
Post Sun Mar 27, 2011 7:22 pm
I now installed twonky on my PC and there I do not exprience such "stuttering". I mean: with serviio I have complete interrupts (picture stands still), with twonky on my PC I have sort of "micro-stuttering" during pan shots which I don't experience with twonky on my NAS. I checked my cables (all CAT5) and tried others without success. :(
Post Sun Mar 27, 2011 8:06 pm
Is it possible that Twonky transcodes the file and lowers the bitrate?
dag0
Post Sun Mar 27, 2011 8:53 pm
I don't know why, but transcoding options for video and foto are grayed out on NAS and PC-Twonkyserver. So there obviously is no transcoding happening.
Post Mon Mar 28, 2011 11:59 am
dag0 wrote:I don't know why, but transcoding options for video and foto are grayed out on NAS and PC-Twonkyserver. So there obviously is no transcoding happening.
grayed out option just mean you cant change it doesnt mean its not doing it...
dag0
Post Mon Mar 28, 2011 2:07 pm
While playing a Full-HD-mkv twonky produces about max 5% CPU-load on my NAS. I suppose transcoding would produce a higher CPU-Load?
Post Mon Mar 28, 2011 2:17 pm
I suppose they disable transcoding on NAS to avoid high CPU usage, so you're right. I'm not sure why the stuttering accurs
dag0
Post Mon Mar 28, 2011 2:24 pm
Unfortunately transcoding is disabled on my PC-TwonkyServer too. But this gets off-topic in a serviio-forum! ;)
