Serviio disconnects from C6500
smithj33
Post Mon Mar 28, 2011 4:26 pm
I have been using serviio fine for a couple of months and then last week it stopped working. Now, when I can get it to show up on my 6500, it will disconnect about 5-10 seconds later. Serviio is installed on a Server 2003 machine which has had no changes in a long time besides typical updates. My 6500 can see PlayOn and any other DNLA servers. Windows Firewall is turned off. I tried disabling all other media server apps and disabled my antivirus. I installed 0.5.2 last night and still the same issue. Here is the last Info log and Debug log.
Thanks!
Serviio_Debug.txt
(15.31 KiB) Downloaded 898 times
Serviio_Info.txt
(2.92 KiB) Downloaded 964 times
Post Mon Mar 28, 2011 4:47 pm
Re: Serviio disconnects from C6500
I assume 192.168.0.12 is your PC address. I don't see anything wrong in the log.
smithj33
Post Mon Mar 28, 2011 4:51 pm
Yeah, that is the server. Any suggestions? I am going to try an capture some debug info when it connects and disconnects. I'll post that in a few.
smithj33
Post Mon Mar 28, 2011 5:09 pm
Here is a complete log. I started the service, then the serviio console, then connected with my 6500 and it disconnected after 5 seconds, then I stopped the serviio server. Looks like there might be some issues this time.
(34.94 KiB) Downloaded 951 times
Post Mon Mar 28, 2011 6:24 pm
NOthing in the log I'm affraid. Did you click on StopServer in the console?
smithj33
Post Mon Mar 28, 2011 8:13 pm
I stopped the service and the server from the console, then restarted both. I really liked Serviio, oh well, back to TVMobili... Thanks
smithj33
Post Mon Apr 04, 2011 4:23 am
Just wanted to provide an update. Not sure why this was, but my Western Digital box could see all my DNLA stuff just fine, but obviously the Samsung couldn't. I traced it back to the router, D-Link DI655. I reset the router back to defaults and all my stuff started working again. The other strange thing is that nothing had been changed on the router in months, so not sure why it stopped sending uPNP info to the Samsung. Flaky router I suppose.... Anywho, TVMobili is gone and Serviio is back to my default server app!
Post Mon Apr 04, 2011 5:00 pm
smithj33 wrote:Just wanted to provide an update. Not sure why this was, but my Western Digital box could see all my DNLA stuff just fine, but obviously the Samsung couldn't. I traced it back to the router, D-Link DI655. I reset the router back to defaults and all my stuff started working again. The other strange thing is that nothing had been changed on the router in months, so not sure why it stopped sending uPNP info to the Samsung. Flaky router I suppose.... Anywho, TVMobili is gone and Serviio is back to my default server app!
Good to hear you came back to us :) and d-link home user routers are known for having hissy fits and not wanting to play ball.
smithj33
Post Wed Apr 06, 2011 11:36 pm
Actually it didn't work for very long, but I was digging through the router and noticed Multicast was disabled. Enabled it and has been working flawless. Thanks for a great product.
wher2guv
Post Tue Apr 26, 2011 8:55 pm
Not sure if this is of any help but I have solved my issues with drop outs by not connecting through the adsl router, but using a 4 port hub.
So I connected the TV to the 4 port Hub
the Server to the 4 port Hub
and the
Router to the 4 port Hub
My original post is here
viewtopic.php?f=4&t=731&p=3710&hilit=homehub#p3710
Post Tue Apr 26, 2011 8:58 pm
Thanks for the feedback!
