Serviio does not work
LFG
Post Wed Jul 18, 2018 8:44 pm
The service ends shortly after the start. The log shows the following error:
2018-07-18 22:36:48,059 INFO [ProfileManager] User profiles definition (user-profiles.xml) not found, using built-in profiles only
2018-07-18 22:36:48,090 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2018-07-18 22:36:48,090 INFO [PluginCompilerThread] Started looking for plugins
2018-07-18 22:36:48,090 INFO [UpdateChecker] Checking if a new version is available
2018-07-18 22:36:48,090 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path C:\Program Files\Serviio\bin\\..\lib\ffmpeg.exe
2018-07-18 22:36:48,106 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib\ffmpeg.exe
2018-07-18 22:36:48,137 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: FFMPEG not found. Serviio will not work properly.
java.lang.ExceptionInInitializerError
at org.serviio.MediaServer.main(MediaServer.java:144)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at com.exe4j.runtime.LauncherEngine.launch(LauncherEngine.java:62)
at com.exe4j.runtime.WinLauncher$2.run(WinLauncher.java:96)
Caused by: java.lang.RuntimeException: FFMPEG not found. Serviio will not work properly.
at org.serviio.external.FFMPEGWrapper.loadFFmpegInfo(FFMPEGWrapper.java:138)
at org.serviio.external.FFMPEGWrapper.<clinit>(FFMPEGWrapper.java:111)
... 7 more
2018-07-18 22:36:48,137 WARN [IndexedDiskCache] Region [subtitles_metadata] Disk cache not shutdown properly, shutting down now.
2018-07-18 22:36:48,137 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2018-07-18 22:36:48,137 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2018-07-18 22:36:48,137 WARN [IndexedDiskCache] Region [subtitles] Disk cache not shutdown properly, shutting down now.
The path for ffmeg contains 2 consecutive backslashs. Is this correct?
ffmpeg is in place and seems to be ok for me:
PS C:\Program Files\Serviio\lib> .\ffmpeg.exe
ffmpeg version 3.2.4 Copyright (c) 2000-2017 the FFmpeg developers
built with gcc 4.9.3 (GCC)
configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-libass --enable-librtmp --enable-fontconfig --enable-libfreetype --enable-zlib --enable-libx264 --enable-libspeex --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-mingw32- --enable-gpl --pkg-config=pkg-config --bindir='/jenkins/workspace/FFmpeg - Win32/target'
libavutil 55. 34.101 / 55. 34.101
libavcodec 57. 64.101 / 57. 64.101
libavformat 57. 56.101 / 57. 56.101
libavdevice 57. 1.100 / 57. 1.100
libavfilter 6. 65.100 / 6. 65.100
libswscale 4. 2.100 / 4. 2.100
libswresample 2. 3.100 / 2. 3.100
libpostproc 54. 1.100 / 54. 1.100
Use -h to get full help or, even better, run 'man ffmpeg'
What can I do to make the software work?
My environment:
Windows 10 version 1803
Serviio 1.9.2
Post Wed Jul 18, 2018 9:51 pm
Re: Serviio does not work
can you post the detailed log from the beginning?
LFG
Post Thu Jul 19, 2018 5:51 am
serviio.log:
2018-07-18 22:36:46,403 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2018-07-18 22:36:46,403 INFO  [MediaServer] ------------------------------------------------------------------------
2018-07-18 22:36:46,403 INFO  [MediaServer] Serviio DLNA media streaming server v 1.9.2 (rev. a7a40a8528c7)
2018-07-18 22:36:46,403 INFO  [MediaServer] Petr Nejedly 2009-2017
2018-07-18 22:36:46,403 INFO  [MediaServer] http://www.serviio.org
2018-07-18 22:36:46,403 INFO  [MediaServer] Java 1.8.0_162-Oracle Corporation x86
2018-07-18 22:36:46,403 INFO  [MediaServer] OS Windows 10 10.0
2018-07-18 22:36:46,403 INFO  [MediaServer] File encoding: windows-1252
2018-07-18 22:36:46,434 INFO  [MediaServer] Headless mode enabled: true
2018-07-18 22:36:46,434 INFO  [MediaServer] User: PC07$
2018-07-18 22:36:46,434 INFO  [MediaServer] User home dir: C:\WINDOWS\system32\config\systemprofile
2018-07-18 22:36:46,434 INFO  [MediaServer] Temp dir: C:\WINDOWS\TEMP\
2018-07-18 22:36:46,434 INFO  [MediaServer] ------------------------------------------------------------------------
2018-07-18 22:36:46,434 DEBUG [MediaServer] Runtime params: -Dexe4j.semaphoreName=Local\c:_program_files_pc5dczc_bin_serviioservice.exe0, -Dexe4j.isService=true, -Dexe4j.moduleName=C:\Program Files\Serviio\bin\ServiioService.exe, -Dexe4j.tempDir=C:\WINDOWS\TEMP\e4j9982.tmp_dir1531946206, -Dexe4j.unextractedPosition=413627, -Djava.library.path=C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\PHP\v5.6;C:\Program Files (x86)\Common Files\Intel\Shared Files\cpp\bin\Intel64;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS Client\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Intel\OpenCL SDK\2.0\bin\x86;C:\Program Files (x86)\Intel\OpenCL SDK\2.0\bin\x64;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\Common Files\Intel\WirelessCommon\;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Common Files\Acronis\SnapAPI\;C:\Program Files (x86)\Windows Live\Shared;C:\Program Files\Microsoft SQL Server\110\Tools\Binn\;C:\Pro;C:\Program Files\MySQL\MySQL Server 5.5\bin;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\Calibre2\;C:\WINDOWS\System32\OpenSSH\;C:\WINDOWS\system32\config\systemprofile\AppData\Local\Microsoft\WindowsApps;c:\program files\serviio\jre\bin, -Dexe4j.consoleCodepage=cp0, -Xms20M, -XX:+UseG1GC, -XX:GCTimeRatio=1, -XX:MinHeapFreeRatio=10, -XX:MaxHeapFreeRatio=20, -Djava.net.preferIPv4Stack=true, -Djava.awt.headless=true, -Dorg.restlet.engine.loggerFacadeClass=org.restlet.ext.slf4j.Slf4jLoggerFacade, -Dserviio.home=C:\Program Files\Serviio\bin\\.., -Dderby.system.home=C:\Program Files\Serviio\bin\\..\library, -Xmx512m, -Xrs
2018-07-18 22:36:46,449 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2018-07-18 22:36:46,449 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2018-07-18 22:36:46,449 INFO  [DatabaseManager] Using DERBY database language
2018-07-18 22:36:46,934 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2018-07-18 22:36:46,934 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2018-07-18 22:36:46,934 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2018-07-18 22:36:46,934 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2018-07-18 22:36:46,934 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2018-07-18 22:36:46,934 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2018-07-18 22:36:46,934 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2018-07-18 22:36:46,934 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2018-07-18 22:36:46,934 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2018-07-18 22:36:46,934 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2018-07-18 22:36:46,934 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2018-07-18 22:36:46,934 DEBUG [DBLogDAOImpl] Checking if script 'script-1.0.sql' has been run
2018-07-18 22:36:46,934 DEBUG [DBLogDAOImpl] Checking if script 'script-1.1.sql' has been run
2018-07-18 22:36:46,934 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.sql' has been run
2018-07-18 22:36:46,934 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.1.sql' has been run
2018-07-18 22:36:46,934 DEBUG [DBLogDAOImpl] Checking if script 'script-1.3.sql' has been run
2018-07-18 22:36:46,934 DEBUG [DBLogDAOImpl] Checking if script 'script-1.4.sql' has been run
2018-07-18 22:36:46,934 DEBUG [DBLogDAOImpl] Checking if script 'script-1.5.sql' has been run
2018-07-18 22:36:46,934 DEBUG [DBLogDAOImpl] Checking if script 'script-1.6.sql' has been run
2018-07-18 22:36:46,934 DEBUG [DBLogDAOImpl] Checking if script 'script-1.7.sql' has been run
2018-07-18 22:36:46,934 DEBUG [DBLogDAOImpl] Checking if script 'script-1.8.sql' has been run
2018-07-18 22:36:46,949 DEBUG [DBLogDAOImpl] Checking if script 'script-1.9.sql' has been run
2018-07-18 22:36:47,012 INFO  [WebServer] Socket buffer set to 65535 bytes
2018-07-18 22:36:47,012 INFO  [RestletServer] Starting HTTP/1.1 Restlet server (/console) exposed on port 23423
2018-07-18 22:36:47,012 INFO  [RestletServer] Starting HTTP/1.1 Restlet server (/rest) exposed on port 23423
2018-07-18 22:36:47,012 INFO  [RestletServer] Starting HTTPS/1.1 Restlet server (/console) exposed on port 23523
2018-07-18 22:36:47,012 INFO  [RestletServer] Starting HTTPS/1.1 Restlet server (/rest) exposed on port 23523
2018-07-18 22:36:47,465 INFO  [RestletServer] Starting HTTP/1.1 Restlet server (/cds) exposed on port 23424
2018-07-18 22:36:47,465 INFO  [RestletServer] Starting HTTP/1.1 Restlet server (/mediabrowser) exposed on port 23424
2018-07-18 22:36:47,465 INFO  [RestletServer] Starting HTTPS/1.1 Restlet server (/cds) exposed on port 23524
2018-07-18 22:36:47,465 INFO  [RestletServer] Starting HTTPS/1.1 Restlet server (/mediabrowser) exposed on port 23524
2018-07-18 22:36:47,481 DEBUG [LicensingManager] Updating license
2018-07-18 22:36:47,481 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2018-07-18 22:36:47,496 DEBUG [LicenseValidator] Validating license file (350 bytes)
2018-07-18 22:36:47,527 INFO  [MediaServer] ------------------------------------------------------------------------
2018-07-18 22:36:47,527 INFO  [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2018-07-18 22:36:47,527 DEBUG [LocalAddressResolverStrategy] Resolving host IP address automatically
2018-07-18 22:36:47,746 INFO  [Device] Created UPnP Device with UUID: d87e4353-8d8f-369f-8555-031cbff7629c, bound address: 192.168.178.31
2018-07-18 22:36:47,809 INFO  [ProfileManager] Loading profiles from file /profiles.xml
2018-07-18 22:36:47,965 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2018-07-18 22:36:47,965 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2018-07-18 22:36:47,981 INFO  [CustomisationManager] No customisation properties found
2018-07-18 22:36:48,012 INFO  [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2018-07-18 22:36:48,012 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2018-07-18 22:36:48,012 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2018-07-18 22:36:48,012 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2018-07-18 22:36:48,027 INFO  [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2018-07-18 22:36:48,027 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2018-07-18 22:36:48,027 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2018-07-18 22:36:48,027 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile ps4
2018-07-18 22:36:48,027 INFO  [ProfilesDefinitionParser] Added profile 'Playstation 4' (id=ps4)
2018-07-18 22:36:48,027 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2018-07-18 22:36:48,027 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2018-07-18 22:36:48,027 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2018-07-18 22:36:48,027 INFO  [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2018-07-18 22:36:48,027 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sam_h
2018-07-18 22:36:48,027 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (H-series)' (id=sam_h)
2018-07-18 22:36:48,027 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sam_j
2018-07-18 22:36:48,027 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (J-series)' (id=sam_j)
2018-07-18 22:36:48,027 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sam_m
2018-07-18 22:36:48,027 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (M-series)' (id=sam_m)
2018-07-18 22:36:48,027 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sam_ef
2018-07-18 22:36:48,027 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2018-07-18 22:36:48,027 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2018-07-18 22:36:48,027 INFO  [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2018-07-18 22:36:48,027 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2018-07-18 22:36:48,027 INFO  [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2018-07-18 22:36:48,027 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012
2018-07-18 22:36:48,027 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2018-07-18 22:36:48,027 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2013
2018-07-18 22:36:48,027 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013/14)' (id=sony2013)
2018-07-18 22:36:48,027 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2013
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2012
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010us
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2011
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile tosh2012
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2010
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile plps2010
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2009
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 22
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2013
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011a
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2010
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2009
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2009)' (id=viera2009)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012us
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011us
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonySTR
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonyCMT
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viziotv
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile panasonicBDT220
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile philips_streamium
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile roku
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile RokuMPApp
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile Roku4kMPApp
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Roku 4K Media Player (2016+)' (id=Roku4kMPApp)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile RokuNo4kApp
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Roku 1080 Media Player (2016+)' (id=RokuNo4kApp)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile RokuTV
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Roku TV (non 4K)' (id=RokuTV)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile Roku4kTV
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Roku 4K TV' (id=Roku4kTV)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile YamBD
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile TNDC
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile xbox_one
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2018-07-18 22:36:48,043 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile raumfeld
2018-07-18 22:36:48,043 INFO  [ProfilesDefinitionParser] Added profile 'Raumfeld' (id=raumfeld)
2018-07-18 22:36:48,043 INFO  [ProfileManager] Loading profiles from file /application-profiles.xml
2018-07-18 22:36:48,059 INFO  [ProfilesDefinitionParser] Parsing Profiles definition
2018-07-18 22:36:48,059 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile flv_player
2018-07-18 22:36:48,059 INFO  [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2018-07-18 22:36:48,059 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile html5
2018-07-18 22:36:48,059 INFO  [ProfilesDefinitionParser] Added profile 'HTML5' (id=html5)
2018-07-18 22:36:48,059 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile html5_mobile
2018-07-18 22:36:48,059 INFO  [ProfilesDefinitionParser] Added profile 'HTML5 Mobile' (id=html5_mobile)
2018-07-18 22:36:48,059 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_standard
2018-07-18 22:36:48,059 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2018-07-18 22:36:48,059 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2018-07-18 22:36:48,059 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_hls
2018-07-18 22:36:48,059 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2018-07-18 22:36:48,059 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_gtv
2018-07-18 22:36:48,059 INFO  [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2018-07-18 22:36:48,059 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile googlecast
2018-07-18 22:36:48,059 INFO  [ProfilesDefinitionParser] Added profile 'Google Cast' (id=googlecast)
2018-07-18 22:36:48,059 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile chromecast
2018-07-18 22:36:48,059 INFO  [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
   ... 7 more
2018-07-18 22:36:48,137 WARN  [IndexedDiskCache] Region [tokens] Disk cache not shutdown properly, shutting down now.
2018-07-18 22:36:48,215 INFO  [TrakttvService] Started trakt.tv sync updater
2018-07-18 22:36:48,215 INFO  [TrakttvService] Started trakt.tv scrobble poster
2018-07-18 22:36:48,231 INFO  [FileDeltaWatcher] Using 'sun.nio.fs.WindowsWatchService' for delta scan
2018-07-18 22:36:48,231 INFO  [LibraryOneTimeScanner] Interrupting library scan
2018-07-18 22:36:48,231 DEBUG [LibraryOneTimeScanner] Library scan has been interrupted
2018-07-18 22:36:48,231 INFO  [PluginCompilerThread] Finished looking for plugins
2018-07-18 22:36:48,340 INFO  [SearchManager] Starting up search engine
2018-07-18 22:36:48,465 INFO  [SearchIndexer] Closing search index writer
2018-07-18 22:36:48,481 INFO  [PlaybackProgressUpdater] Started playback progress updater
2018-07-18 22:36:48,496 INFO  [RendererSearchSender] Stopping Renderer searcher process
2018-07-18 22:36:48,512 INFO  [DatabaseManager] Shutting down database
2018-07-18 22:36:48,512 DEBUG [DBConnectionPool] Closed connection for pool Serviio DB Pool
2018-07-18 22:36:48,527 WARN  [DatabaseManager] DB shutdown returned: Derby system shutdown.
2018-07-18 22:36:48,543 INFO  [AbstractAVTranscodingDeliveryEngine] Cleaning transcode engine and its data
derby.log:
Wed Jul 18 22:36:46 CEST 2018:
Booting Derby version The Apache Software Foundation - Apache Derby - 10.12.1.1 - (1704137): instance a816c00e-0164-af1c-056e-ffff8366333d
on database directory C:\Program Files\Serviio\library\db with class loader sun.misc.Launcher$AppClassLoader@387f44
Loaded from file:/C:/Program%20Files/Serviio/lib/derby.jar
java.vendor=Oracle Corporation
java.runtime.version=1.8.0_162-b12
user.dir=C:\Program Files\Serviio\bin
os.name=Windows 10
os.arch=x86
os.version=10.0
derby.stream.error.file=../log/derby.log
Database Class Loader started - derby.database.classpath=''
Wed Jul 18 22:36:48 CEST 2018: Shutting down Derby engine
Shutting down instance a816c00e-0164-af1c-056e-ffff8366333d on database directory C:\Program Files\Serviio\library\db with class loader sun.misc.Launcher$AppClassLoader@387f44
Post Thu Jul 19, 2018 12:03 pm
that is weird, all looks ok
can you check if the ffmpeg.exe file has some special file ttrbutes, like non-readable / executable /blocked for any user? note that Serviio is run under our service user, not the logged in one.
LFG
Post Sat Jul 21, 2018 9:55 am
I found the cause. The Comodo HIPS component has prevented Serrviio interprocess communication without warnings or notifications. Now everything is going as expected.
@zip
Thank you for your support!
Users browsing this forum: Baidu [Spider] and 249 guests
