How to update
JobbeDeluxe
Post Sun Jul 22, 2018 7:58 am
How to update
I try to update serviio from 1.9 to 1.9.2
I downloaded, unpack and copy the config and library folder to the new folder. Server started, but it showed the old versions number. What did I wrong?
Post Mon Jul 23, 2018 10:17 am
Re: How to update
which OS?
JobbeDeluxe
Post Tue Jul 24, 2018 4:42 pm
Re: How to update
Raspbian on a raspberry pi 3.
Post Tue Jul 24, 2018 7:06 pm
Re: How to update
did you unpack 1.9.2 and then copy over the library folder from your older version?
JobbeDeluxe
Post Wed Jul 25, 2018 11:32 am
Re: How to update
The library and the config folder. I don't wanna loose my settings.
Post Thu Jul 26, 2018 10:09 am
Re: How to update
the version definitely comes from the serviio.jar file, inside the lib forder (not library). Make sure you have those new files in there.
JobbeDeluxe
Post Thu Jul 26, 2018 5:03 pm
Re: How to update
I think I found my problem. The user for the new folders was 288. I changed to pi and make it readable with chmod 777. now it shows the New Version. It was my mistake
