Serviio on Synology STOPPED since last DSM Update
Charles Francis H.
Post Tue Jul 24, 2018 9:55 pm
I'm using Serviio Pro long time on Syno DS916 but since todays Syno DSM Update Serviio permanently is "stopped". Clicking "Run" does not help.
Servvio version installed: 1.9.2-0035
DSM version: 6.2-23739 Update 2
Java version: 1.8.0_171-0047
Tried to reinstall Serviio without any change. Is this an actual problem?
Thanks a lot!!
Charles Francis H.
Post Thu Jul 26, 2018 10:00 pm
Re: Serviio on Synology STOPPED since last DSM Update
Does nobody has an idea? Could I activate a logging or anything else to post here for some details to be analyzed?
JesseBlue78
Post Fri Jul 27, 2018 5:59 pm
i have exact the same Problem on a DS216+II since last DSM update.
Charles Francis H.
Post Fri Jul 27, 2018 7:17 pm
JesseBlue78 wrote:Hello,
Okay...... Thanks for your reply JesseBlue78. Hope someone could help?!? :oops:
bgaherty
Post Fri Jul 27, 2018 8:25 pm
I am having the same issue with my DS916+...just stopped working. Synology seems to think it is because I have 2 LAN connections, but I have had those since day 1, with no issues.
thatfellow
Post Fri Jul 27, 2018 11:43 pm
Same issue on DS1817+
When I try to manually run serviio from DSM package center, the button option changes from Run to install then back to run but nothing happens.
the Log only shows:
2018-07-27 22:51:57,000 Starting Serviio
Unrecognized option: --add-modules
Error: Could not create the Java Virtual Machine.
Error: A fatal exception has occurred. Program will exit.
This happened immediately after DSM 6.2-23739 Update 2.
I have reinstalled Serviio & latest official Java, No change.
Something in the last DSM update has broke the serviio install.
Hope someone can help. I had just updated to Pro version.
One that note, I am surprised to see so few posts on this topic, is it only the upgraded Pro version that is affected?
bgaherty
Post Sat Jul 28, 2018 12:53 am
Same with me. Did a complete reinstall and still nothing...and using the pro-version.
JesseBlue78
Post Sat Jul 28, 2018 11:10 am
thatfellow wrote:Same issue on DS1817+
the Log only shows:
exact the same to me
bgaherty
Post Sat Jul 28, 2018 5:27 pm
So is there anyone that can help...or is this a dead thread/forum?
Airborne1
Post Mon Jul 30, 2018 11:24 am
bgaherty wrote:So is there anyone that can help...or is this a dead thread/forum?
Maybe the user "patters" can help. But he hasn't been online for about 2 weeks, probably on a holiday.
See: https://pcloadletter.co.uk/2012/01/25/s ... o-package/
Post author is patters.
I have already posted this issue in his support thread: viewtopic.php?f=14&t=3311&start=320
Saintsan
Post Thu Aug 02, 2018 11:25 am
Have the same problem. Tried installing today on Synology 416play and cannot start serviio at all.
Airborne1
Post Thu Aug 02, 2018 11:44 am
My guess is that an update of the Java SE Embedded 8 packet is needed, to support the latest version 181. The current packet installs 171...
thatfellow
Post Sat Aug 04, 2018 7:10 pm
I went through the issue with Synology support.
Not exactly the most helpful reply but at lease we know that this is Serviio's problem to solve.
Hi
Thank you for contacting Synology Support.
Unfortunately Serviio is not an officially supported package for Synology and is not available on the default Package Center. As such we are unable to provide assistance with installing this application, for this particular issue, we can only recommend to contact the developer of the package to request assistance with installation, or to submit the application to Synology for addition to the Package Center to be officially available for our devices.
Best Regards
Craig
Technical Support
Airborne1
Post Sat Aug 04, 2018 7:45 pm
thatfellow wrote:I went through the issue with Synology support.
Hi
Best Regards
Craig
Technical Support
Ack, got a similar answer to my ticket.
I wonder, is there an official Synology NAS support by Serviio?
bgaherty
Post Sat Aug 04, 2018 9:56 pm
Hi
Best Regards
Craig
Technical Support
I received the exact same message. You would think if they developed the app for synology, they would support it. Is there any other way to get Serviio reps to respond...other than this forum?
Post Sun Aug 05, 2018 1:43 am
The Serviio author does not create the versions for NAS devices. Third parties provide the versions for the NAS devices. I don't know who was responsible for the Synology version, but I do know user Patters provides some NAS support.
Yes, this forum is the only place for user support. Zip is the (only) developer, but as I said he isn't responsible for the NAS versions.
Post Mon Aug 06, 2018 1:48 pm
I'll ping patters to see if he can help.
Airborne1
Post Mon Aug 06, 2018 3:32 pm
zip wrote:I'll ping patters to see if he can help.
OK thanks! :-)
Charles Francis H.
Post Tue Aug 07, 2018 7:26 pm
Thank you zip!! If we can do anything to help you, patters or anybody else to solve the problem, let us know. E.g. logfiles, see my other thread http://forum.serviio.org/viewtopic.php?f=5&t=24651&p=118378#p118378 - I would provide logs for research but don't know where to get them from telnet console...
patters
Post Fri Aug 10, 2018 9:35 am
This is strange because my DS214play is running that same DSM version with no problems. The issue for you guys seems to be that the Java executable will no longer start. I wonder if this is a 32/64bit issue – perhaps the Synology developers have made a change that is preventing the 32bit Java Embedded from running. The CPU in my NAS is unique in that it’s a 32bit only chip (so maybe that’s why it still works), whereas pretty much every single other Intel Syno runs a 64bit build of Linux. I will update the Java package with a 32/64bit selection for Intel x64 capable CPUs. Let’s see if that fixes it.
If it's Java that won't start, even with the Synology-published Java package, then it should be supported by Synology since that's a first party package. Test this by removing my Java Embedded package, installing the Syno one and then running "java -version" in an SSH session. If it fails to run then that is most certainly something Synology should be supporting.
