Renderer error
AQUSTIQ
Post Mon May 28, 2018 7:36 pm
Renderer error
Can anybody help me with following error that I'm getting with my LGTV 55LB6500 connected over WiFi:
2018-05-27 19:00:28,191 WARN  [RendererManager] Error while retrieving renderer description from http://192.168.10.4:1470/: connect timed out
I have a lot of them.
When this happens my TV throw a notification that network was lost. To bypass this sometimes I have to restart my TV or restart serviio service.
I have to notice that I have no issue to watch any on-line resources as Youtube or Dailymotion.
I have tested also my Wireless connection with laptop and didn't get any disconnections.
P.S. I use serviio 1.9.2 on Debian 9
Post Wed May 30, 2018 1:02 pm
Re: Renderer error
That means that Serviio is trying to connect to the TV and fetch its description, but the request times out - due to network or the TV stopping responding.
No idea why, you could try wired network or change some settings on the router.
AQUSTIQ
Post Mon Jul 09, 2018 6:57 pm
Re: Renderer error
zip wrote:That means that Serviio is trying to connect to the TV and fetch its description, but the request times out - due to network or the TV stopping responding.
The bad part that I don't have router between them.
Serviio Server => Switch => WAP => LG TV
2018-07-09 07:36:26,643 WARN  [RendererManager] Error while retrieving renderer description from http://192.168.10.4:1382/: connect timed out
2018-07-09 07:36:26,841 WARN  [RendererManager] Error while retrieving renderer description from http://192.168.10.4:1382/: connect timed out
2018-07-09 07:36:27,644 WARN  [RendererManager] Error while retrieving renderer description from http://192.168.10.4:1382/: connect timed out
2018-07-09 07:36:27,842 WARN  [RendererManager] Error while retrieving renderer description from http://192.168.10.4:1382/: connect timed out
2018-07-09 07:36:31,813 WARN  [EventDispatcher] Couldn't send event message for subscription bda55d87-2933-42ca-83a6-006774ba1c1c, will keep $
Post Mon Jul 09, 2018 7:37 pm
Re: Renderer error
Since you were using a WAP, rather than a router for your wireless, his comment about trying any setting changes would apply to your WAP. Make sure Multicast is enabled, for one.
AQUSTIQ
Post Fri Jul 27, 2018 2:40 pm
Re: Renderer error
atc98092 wrote:Since you were using a WAP, rather than a router for your wireless, his comment about trying any setting changes would apply to your WAP. Make sure Multicast is enabled, for one.
Thank you DAN for answer. I found that problem was my D-Link switch. Seems like these guys don't know how to built reliable switches :)
Post Sat Jul 28, 2018 6:42 pm
Re: Renderer error
I've never had much success with D-Link myself. I have one of their mobile routers, and I can rarely get it to act as a bridge with hotel wireless like it's supposed to.
Return to General discussion
Users browsing this forum: Baidu [Spider] and 20 guests
