can start stop manually the service on windows 10
glda19
Post Sun Aug 12, 2018 6:47 pm
Hi
I set on windows 10 the services for serviio on manual. I did that services.msc
than right click options and startup manuallay
If i try to start the serviio services by clicking in the startmenu on start serviio service
NOTHING happend.
And when i click on start in services.msc. And click on start stop its switch directly to start or stop.
But not bye "C:\Program Files\Serviio\bin\ServiioService.exe" -stop or "C:\Program Files\Serviio\bin\ServiioService.exe" -start that is in windows menu serviio why
In the past it works
Greetings Glenn
glda19
Post Sun Aug 12, 2018 7:06 pm
Re: can start stop manually the service on windows 10
I Found what the problem is
But the logon user ave administror rights
The services can only start strop as administror.
So i test i on the windows menu serviio richt klik on start service serviio start as administator and it works.
So i opend the file location richt click on start and stop and -> properties and advanced -> click by run as administor.
