File Organization
palata
Post Sat Aug 11, 2018 6:04 pm
File Organization
Its possible set up so that the movie folder only shows the files set up in the YEAR - MOVIE NAME standard?
Example : 2018 - Avengers - Infinity War
Post Mon Aug 13, 2018 12:30 am
Re: File Organization
Not certain if this is what you are looking for, but on the console under Presentation, Release Years is one of the options. When you are browsing your media on your player, release Years is one of the selections. Opening that, you see each year your media covers.
palata
Post Sat Aug 18, 2018 8:32 pm
No, is not that. The serviio automatically separates what is the movie from the series, putting each one in its folder. 220/5000
But deleted scenes from a movie, for example, are polluting movie viewing. So I would like to see in the movies folder only the files with the name in the format defined, in my case YEAR - MOVIENAME.
