UPnP interface is gone while Web interface still is visible
Post Wed Feb 21, 2018 10:30 am
Re: UPnP interface is gone while Web interface still is visi
So localhost works because it's a loopback address and Serviio skips some steps if the client is a loopback address.
Incoming request from /127.0.0.1:19422
In the IP case, it looks like
Incoming request from /192.168.64.4:19452
It resolves to the server's IP (in both cases), because you're making the request from the same machine (I assume).
Then, in the IP case, it takes 5 minutes, because that piece of code is blocked by another renderer processing (when Serviio is looking for new renderers), which actually times out
Error while retrieving renderer description: Read timed out
So you have to solve this - why Serviio cannot connect to the renderers. For example, is this accessible for Serviio?
http://192.168.64.83:52525/root_XXYY.xml
rhoyer78
Post Wed Feb 21, 2018 2:49 pm
DEBUG [RendererManager] Retrieve device description from http://192.168.64.83:52525/root_XXYY.xml
192.168.64.83 is a "Renkforce IR 1" InternetRadio
The internal Webserver on Port 52525 cashed, after rebooting the "Renkforce IR 1" Serviio showed up again on all devices...
Thanks a lot!
Maybe the RendererManager should not constantly try to poll faulty clients and indicate/block faulty clients at the status page..?
Post Thu Feb 22, 2018 2:22 pm
yeah, I just removed the blocking around the call, so if some are blocking, other clients can still be served
rhoyer78
Post Thu Feb 22, 2018 5:33 pm
Wow that was fast! Thanks a lot and keep up the good work!
hanneshar
Post Sun Aug 26, 2018 5:48 pm
I think I found the solution to my problem - and it has nothing to do with Serviio... Until now I had a FRITZ! box running as a router, which operated both the LAN and the WLAN. Since we have a quite big house, I attached a dLAN 500 AV Wireless+ adapter to the Devolo LAN. It set up its own WLAN, so that I had to choose between WLAN 1 and WLAN 2 in the house. But presumably the FRITZ!box missed any routing tables, which are responsible for a correct allocation of the DLNA devices. Since I have simply removed the dLAN 500 AV Wireless+ adapter from my network, Serviio is always visible from all my DLNA devices. Stupid problem that almost drove me mad at times...
Thanks again here for all the people who tried to find a solution for me.
Greetings,
Hannes
Previous
