m3u Playlist for local mp3 files - how to?
hanneshar
Post Sun Aug 26, 2018 5:37 pm
despite intensive searches, I haven't found a solution for my relatively simple sounding problem with the current version of Serviio. I have different DLNA devices at home for playing MP3 files, which have different capabilities. Furthermore I have a rather complex MP3 collection, which is structured as follows:
- pop music
-- Artist A
--- album 1
--- album 2
--- album 3
---- CD 1
---- CD 2
-- artist B
--- album 1
album 2
- rock
-- Artist A
--- album 1
--- album 2
--- album 3
---- CD 1
---- CD 2
-- artist B
--- album 1
--- album 2
For example, if I want to play all MP3 songs from Popmusic/Artist A now, then some of my DLNA devices can obviously create their own playlist if I just click on Play in the "Popmusic/Artist A" directory. Other DLNA devices only play the MP3 songs that are in the current directory and ignore all other MP3 songs that are in deeper subdirectories. So I had the clever idea to generate m3u playlists in order to let such stupid DLNA devices play all of an artist's subdirectories.
But: how must such a m3u playlist be formatted for Serviio to deliver this file to the DLNA devices? Where do I have to save this m3u playlist? Can I see and select such a m3u playlist in the web interface of Serviio? Is there perhaps a very simple wiki page where the use of such m3u playlists is explained as playing locally stored MP3 songs?
Greetings,
Hannes
MikeL
Post Thu Aug 30, 2018 2:49 pm
Re: m3u Playlist for local mp3 files - how to?
I have a similar issue. I have my music library in iTunes and like you have a hierarchical playlist structure that I would like to make visible through Mediabrowser.
I also wanted that same structure to be available and visible on my Sonos system using my iTunes library as a music source. I was able to get the Sonos system working the way I wanted by writing a program that parsed the playlist structure in the iTunes database and created a corresponding folder\file structure in the Windows file system. Each playlist being a m3u file in this structure. I was then able to import that into Sonos and it works.
I tried to do the same with Mediabrowser by creating an entry in the shared folders for audio files and pointing it to the top folder of my playlist structure. I enabled playlists for audio under the Presentation flag and forced a refresh of the library but it didn't work.
I then created a simpler playlist structure to play with and Serviio only picks up 2 playlists (happens to be a deliberate duplicate one) and ignores all the others and also ignores the folder structure of the playlist library.
I'll keep playing with it and let you know if I get anywhere.
Mike
Post Thu Aug 30, 2018 5:41 pm
Serviio will support playlists as per http://serviio.org/features
These are not hierarchical, so they are just a flat list of files.
1 - add folder with music files and playlists to the library
2 - browse to Audio / Playlists to see the playlists there
hanneshar
Post Sun Sep 02, 2018 10:17 am
Thank you for your help! I've indeed simply missed the option to add "playlist" in the Serviio console. Now it is working great!
:-) Hannes
keneltyler
Post Mon Nov 01, 2021 2:29 pm
This is a quite common problem that people have. This all depends on what device you are listening to. There are a lot of devices that read mp3 files, but they can not read them after they have been put in a folder. The only solution I have found is deleting the tracks that are not in order and downloading them again. I use https://loader.to to convert and download my tracks. If that doesn't work, you can just delete the folder and listen to all the tracks without them being put in categories.
