.WMV file playing without audio on PS3
individual
Post Tue Mar 29, 2011 5:03 am
  built on Mar 26 2011 10:52:39 with gcc 4.2.3
  configuration: --arch=arm --enable-armv5te --prefix=/opt --extra-cflags=-I/opt/include --extra-ldflags=-L/opt/lib --enable-static --disab                   le-shared --disable-ffplay --disable-ffserver --enable-libmp3lame
  libavutil     50.36. 0 / 50.36. 0
  libavcore      0.16. 0 /  0.16. 0
  libavcodec    52.108. 0 / 52.108. 0
  libavformat   52.92. 0 / 52.92. 0
  libavdevice   52. 2. 3 / 52. 2. 3
  libavfilter    1.72. 0 /  1.72. 0
  libswscale     0.12. 0 /  0.12. 0
Seems stream 1 codec frame rate differs from container frame rate: 1000.00 (1000/1) -> 23.98 (24000/1001)
Input #0, asf, from 'IMAX Fighter Pilot - Operation Red Flag 1080p.wmv':
    WM/ParentalRating:
    WMFSDKVersion   : 9.00.00.2991
    WMFSDKNeeded    : 0.0.0.0000
    IsVBR           : 0
    title           :
    artist          :
    copyright       :
    comment         :
  Duration: 00:48:27.90, start: 4.000000, bitrate: 9404 kb/s
    Stream #0.0(eng): Audio: wmapro, 48000 Hz, 5.1, flt, 440 kb/s
    Stream #0.1(eng): Video: wmv3, yuv420p, 1440x1080, 9000 kb/s, PAR 4:3 DAR 16:9, 23.98 tbr, 1k tbn, 1k tbc
Can the PS3 profile be amended so it could play wmapro, 48000 Hz, 5.1 audio streams on PS3? I have video but no sound in PS3.
In console I have Downmix to stereo activated. Testing the file in Windows Media Player, it plays all right.
NAS: DS712+, 2x Seagate ST2000DL003
DLNA Server: Synology, Serviio, Twonky, Plex
DLNA Player: Raspberry Pi Raspbmc
DLNA Tablet: Yatse
Post Tue Apr 26, 2011 7:11 pm
Re: .WMV file playing without audio on PS3
Please, turn on detailed logging (see link signature), you should be able to see the FFmpeg command that is used for the transcode. Try executing the command manually in a terminal window and post the (error) result here.
Post Tue Apr 26, 2011 7:18 pm
If this file is streamed in native format, you could transcode the audio into wmav2 by modifying the profiles.xml
   <Profile id="4" name="Playstation 3" extendsProfileId="1">
      <Detection>
         <HttpHeaders>
            <X-AV-Client-Info>.*PLAYSTATION 3.*</X-AV-Client-Info>
         </HttpHeaders>
      </Detection>
      <MediaFormatProfiles>
      </MediaFormatProfiles>
            remux MKV with any video to MPEG2TS and possibly change audio to ac3, also AVI anfd FLV with H264
         <!-- all other unplayable files just transcode to mpeg2 -->
         <Video targetContainer="mpegts" targetACodec="ac3" targetVCodec="mpeg2video">
            <Matches container="flv" />
         <Video targetContainer="asf" targetACodec="wmav2">
            <Matches container="asf" aCodec="wmapro"/>
Users browsing this forum: Baidu [Spider] and 28 guests
