Serviio problems
Gpl
Post Sun Oct 21, 2018 8:53 pm
Serviio problems
i have tried serviio yesterday and today and i found 2 problems:
(Serrviio Ver 1.10 on OSX 10.13.6)
1) if network settings is set to automatic my tv (Samsung UE40C6000 don't find the server) i have to change and set the ip
2) if i set serviio to start at login i got an error and server don't start, i have to start serviio manually from application folder
how can i solve this ?
Post Mon Oct 22, 2018 1:53 pm
Re: Serviio problems
Gpl wrote:Hello,
For your Serviio PC, I suggest using a static IP address. As to the startup issue, I am unfamiliar with the Mac OS, but Zip will likely want to see your Serviio log.
Gpl
Post Mon Oct 22, 2018 5:49 pm
Thanks for replay, nowi got serviio running (i can browse in tv)
but if i go in console i got this message:
Cannot connect to the server, it doesn't seem to be tunning...
so i quit consolo and restart and works
Where is log file located ?
Post Mon Oct 22, 2018 8:27 pm
I can't say what the full path would be to Serviio on a Mac, but wherever Serviio is installed, there will be a directory under it labeled Log. There are two files in that folder, one for the DB and one for Serviio. The Serviio log is the only one that the developer will need to see.
Post Mon Oct 22, 2018 8:51 pm
Log locations are described here: http://wiki.serviio.org/doku.php?id=detail_logging
Gpl
Post Fri Oct 26, 2018 9:23 pm
Find, i will respond in the other topic with same problem
Users browsing this forum: No registered users and 74 guests
