[Solved] OS X 1.5 console won't start
acricketer
Post Mon Jan 29, 2018 11:55 am
Re: [Solved] OS X 1.5 console won't start
Started to get the "Cannot connect to server, it doesn't seem to be running message" with Mac OS 1.9.
Uninstalled and reinstalled to no avail. Any advice gratefully received.
Post Mon Jan 29, 2018 9:34 pm
Gpl
Post Fri Oct 26, 2018 9:13 pm
same problem 10.13.6 osx
Serviio 1.10
Gpl
Post Fri Oct 26, 2018 9:20 pm
I follow the procedure but i Can't find log file
Gpl
Post Fri Oct 26, 2018 9:26 pm
Here the log
serviio.log.zip
(124.95 KiB) Downloaded 3533 times
Post Sun Oct 28, 2018 7:52 pm
Server starts ok. Maybe your 'localhost' doesn't resolve properly?
Try to go to
http://localhost:23423/console
in a browser. Does that work?
And then try this
http://192.168.1.4:23423/console
THis is your actual (last used) IP address from the log.
Gpl
Post Wed Oct 31, 2018 7:49 pm
Yes seerver starts, i got this error messeg in
Serviio-Console-Wreapper
works
Post Thu Nov 01, 2018 9:35 am
That is weird, because the console wrapper literally just opens this URL in its window.
Gpl
Post Thu Nov 01, 2018 5:44 pm
No solution ?
Hound69
Post Mon Mar 09, 2020 3:57 pm
Help with Console serviio
I get the following message from the Serviio console Wrapper..
"Cannot connect to the server, it doesn't seem to be runing..."
However I have looked through the posts here and when I click on the local host link to open in a browser window, it successfully opens the serviio concole.
I have been trying to get this up and running again for over a week now, Hopefully you genius can help?
Kind Regards
Hound69
Post Sun Mar 29, 2020 4:33 pm
I'd suggest not to bother with the console then and just bookmark the localhost link and use that.
Previous
