Subtitle problem
dockelektro
Post Wed Nov 07, 2018 9:25 am
Subtitle problem
Hi guys, I've been having problems reading subs from srt files on my TV, it used to work perfectly but a while ago the option for subtitles simply stopped appearing. I still have subtitles enabled that are embedded in the mkv file, but if I try to use SRT files they don't show up. I reinstaled serviio to no avail. If I read the mkv file from a usb drive connected the TV, the SRT works fine. I tried various subtitles options in Serviio, but it still doesn't work. Also, the "burned in" subtitles option prevents the file from playing at all. Retrieving subtitles from opensubtitles.org also doesn't work. Thank you for your help.
Post Fri Nov 09, 2018 10:10 am
Re: Subtitle problem
Are you using the correct profile for your TV?
amxin
Post Fri Nov 09, 2018 2:01 pm
Have you tried resetting the settings to defaults
dockelektro
Post Tue Nov 13, 2018 12:31 pm
Hi, turns out the problem lies in my Sony TV default video app. VLC works normally, so no problem with Serviio. Thank you for your replies!
