Unable to see vobsub / Ipad
CynicalDux
Post Fri Nov 09, 2018 1:59 pm
I'm using Serviio 1.10 on ipad with vlc.
When I try to watch some mkv with vlc or or infuse, the vosub subs won't show up or randomly. I enabled the DEBUG level log mode, no errors. I tried with Infuse, no luck.
The subs work fins on the desktop vlc. I tried to update ffmeg version with the lastest, 4.1.0, no luck. I tried several mkv from vobsub ripped from dvds, the problem is the same on all files.
Any ideas why the vobsubs/closed subs won't show up?
R.
(437.38 KiB) Downloaded 348 times
MediaInfo.txt
(4.8 KiB) Downloaded 396 times
Post Mon Nov 12, 2018 11:57 am
Re: Unable to see vobsub / Ipad
did you enable burned-in subtitles? These subs are bitmap based, so the file needs to be transcoded
