video set-up
enfield250
Post Tue Nov 13, 2018 9:39 am
video set-up
hello!
I'm having a problem with videos.
I render my videos with Adobe Premiere Elements 15 as mp4's.
However Serviio will not decode them showing them as "Unsupported file type".
Jpg and Audio files seem to work ok.
Any ideas please?
Post Tue Nov 13, 2018 1:31 pm
Re: video set-up
enfield250 wrote:hello!
Any ideas please?
See the link in my sig line for assistance providing the media information about your files. Just saying they are MP4 is unfortunately not detailed enough to help troubleshoot.
enfield250
Post Tue Nov 13, 2018 2:07 pm
Re: video set-up
Thank you for the quick response.
I use the standard Adobe Premiere set-up for 1080 hd tv.
Res: 1920 x 1080
Format: H.264
Frame Rate: 25fps
Audio: AAC, 160kbps, 48khz stereo
Bitrate: 15mbps.
Below is the media information taken from a mp4 file that does not work (Adobe Premiere)
Complete name : H:\Baddesley Clinton\Baddesley Clinton.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/mp41)
File size : 251 MiB
Duration : 2 min 10 s
Overall bit rate : 16.1 Mb/s
Encoded date : UTC 2018-11-12 15:34:05
Tagged date : UTC 2018-11-12 15:34:05
Format : AVC
Format profile : Main@L4.2
Format settings : CABAC / 3 Ref Frames
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Format settings, GOP : M=4, N=25
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate : 16.0 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.308
Stream size : 249 MiB (99%)
Language : English
Color range : Limited
Color primaries : BT.709
Matrix coefficients : BT.709
Codec configuration box : avcC
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Source duration : 2 min 10 s
Bit rate mode : Variable
Bit rate : 157 kb/s
Maximum bit rate : 251 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 2.45 MiB (1%)
Source stream size : 2.45 MiB (1%)
Language : English
Below is the Media information for a file that does work.
eneral
Complete name : H:\Baddesley Clinton\Plex Versions\Optimized for TV\00018 (2018).mp4
Format : MPEG-4
Codec ID : isom (isom/iso2/avc1/mp41)
File size : 27.0 MiB
Duration : 26 s 944 ms
Overall bit rate : 8 421 kb/s
Writing application : Lavf58.9.100
Format : AVC
Format settings : CABAC / 4 Ref Frames
Format settings, ReFrames : 4 frames
Codec ID : avc1
Duration : 26 s 920 ms
Bit rate : 8 231 kb/s
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.159
Stream size : 26.4 MiB (98%)
Writing library : x264 core 148 r2665 a01e339
Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0 / me=dia / subme=0 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=4 / chroma_me=0 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=4 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=crf / mbtree=1 / crf=16.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=8000 / vbv_bufsize=16000 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : AC-3
Bit rate mode : Constant
Bit rate : 192 kb/s
Frame rate : 31.250 FPS (1536 SPF)
Bit depth : 16 bits
Stream size : 632 KiB (2%)
Service kind : Complete Main
Default : Yes
Alternate group : 1
Hope this gives the information you require to help.
Cheers,
enfield250
Post Tue Nov 13, 2018 2:21 pm
Re: video set-up
Dan,
I have tried to follow your link but unfortunately Intel UPnP tools comes up as not found.
So I tried a different link and got a 404 response.
Cheers
Post Tue Nov 13, 2018 6:12 pm
Re: video set-up
https://software.intel.com/en-us/articl ... load-tools
That link worked for me. But I have to say that Intel hasn't updated the tools for years, so I wouldn't be surprised if they disappear sometime.
I forgot to ask what sort of player you're using that can't play your media. From what you've posted, they appear to be something that most players should support.
