RendererManager Error
rp1428
Post Wed Nov 28, 2018 3:50 pm
I am seeing the following messages in the log file:
2018-11-28 08:04:03,689 WARN [RendererManager] Error while retrieving renderer description from http://169.254.8.24:63445/upnp/xml/devi ... derer1.xml: connect timed out
2018-11-28 08:10:10,611 WARN [RendererManager] Error while retrieving renderer description from http://169.254.166.180:49152/4/description.xml: connect timed out
The IP address listed is private. My network is 192.168.1.0. Can anyone help with where these addresses are coming from or how to get more details of this. In the console, all the devices listed as connecting are 192.168.1.x
Post Wed Nov 28, 2018 10:22 pm
Re: RendererManager Error
The 169.254 address block is self assigned when a network adapter is set for DHCP but is unable to retrieve an IP address from the DHCP server. Check your Serviio computer and make sure it hasn't lost its network connection. It's possible that whatever assigned your IP addresses (usually your primary Internet router) isn't working right. Might try a reboot.
Users browsing this forum: Google [Bot] and 38 guests
